2004 will not start/post with brake pedal.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Blackwing, Aug 22, 2018.
  1. Blackwing
    Blackwing Member
    102
    Hi guys,
    I am trying to jump my 2004 prius with my 2007 e90 BMW.
    My wife said she saw a couple sparks from the negative end on the Prius hood latch when I pressed the brake pedal to start it.
    I replaced the 12v aux in the Prius myself back in 2011. It is an OEM 12v from Toyota dealer.
    Do I need to replace the battery? Should I get jumper cables with some kind of easy monitoring feature?
    Is it something else?
  2. JC91006
    16,926
    8,637
    I don't think the hood is a proper ground, you should use the strut tower nut next to the positive connection on the prius.
    Also doesn't the good battery (bmw) have to be fully connected? Positive and negative terminal on battery
    Raytheeagle likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    I'm confused by your connections. The prius has the (+) cable connected to the jump point under the hood with the (-) cable connected to hood latch (unusual)
    But more than that, what is the red cable (+) connected to on the BMW? I'm not familiar at all with BMW construction. Is that a jump point also? The (-) cable appears to be connected to the battery. I'm not familiar at all with BMW construction
  4. Blackwing
    Blackwing Member
    102
    I'm not sure if I am doing it configuration properly.
    However every BMW E90 video I watched, those are the 2 terminal points.
    The prius I might need to use the nut like you said.
    Was jumping it for about 10-15 minutes and no noises when I hit the brake pedal. Just a spark or two.
  5. Blackwing
    Blackwing Member
    102
    Do I need to attach the jumper cables to the BMW battery or the jump points?
  6. JC91006
    16,926
    8,637
    if you can get to the battery, attach it to the battery terminal itself. If it's hard to get to, maybe you can just flag down a fella that will help with a jump start?
  7. Blackwing
    Blackwing Member
    102
    Ah okay, so let me get this straight.
    Whenever a battery needs a jump-start, the car with the good battery should have the jumper cables attached to the battery itself always?
    P.S. thanks JC for helping me last year with my Inverter Pump and especially the Coolant Control Valve.
  8. JC91006
    16,926
    8,637
    Yes, good battery fully connected positive and negative. Dead battery gets positive and ground.
  9. Blackwing
    Blackwing Member
    102
    Okay that's probably what I did wrong. Maybe it was pulling charge but hardly any.
  10. Blackwing
    Blackwing Member
    102
  11. JC91006
    16,926
    8,637
    The Prius battery is in the right rear of the trunk/hatch area. But the jump points you have for the Prius is correct, just the ground may not be correct (as the hood is aluminum). Try grounding on the strut nut and I think you'll have better contact.
    To get a battery reading, a simple tool would be a multi meter
  12. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    This is one of those cases where the OP should have read the owners manual of both cars before attempting a jump start.
    It's time for a new one.
  13. Blackwing
    Blackwing Member
    102
    Bought a battery tester to monitor the charge. Will arrive tomorrow
  14. Blackwing
    Blackwing Member
    102
    What are the voltage levels I should be looking out for with the Prius 12v?
    Also, I pasted another pic below. Did I actually clamp the wrong piece?
    #14 Blackwing, Aug 22, 2018
  15. JC91006
    16,926
    8,637
    The 12v battery you have not is probably toast, but you can try to charge it and see if it'll hold the charge. If it won't hold the charge (checking after it sits for 12 hours after charging), you'll need to replace it. Not holding charge would be fully charged 12.9v down to low 12v or less overnight
    A fully charged battery will be around 12.9v. A still functional battery will be around 11.5v (meaning it'll still start the car). You really want to charge up a battery that reads around 12v or less, as the car probably won't be able to fully charge it at that level.
  16. Blackwing
    Blackwing Member
    102
    I forgot to reply back nearly a year later. The last screenshot explains it. I was clamping the nut beneath the terminal instead of the actually "flat-shaped" terminal itself. I've used the terminal several times since the last post. Topic closed.
  17. Patrick Wong
    18,210
    6,517
    If your jumper cable alligator clamp was sufficiently small so that it would have a good connection to the threaded stud and nut, that would work. However most clamps are too large, hence the flat terminal above that is intended as the dedicated positive terminal jump point.
    The need to use the terminal "several times" is not good. That implies the 12V battery is dead and needs to be replaced; or the car is driven very lightly and a battery charger or battery tender should be used to keep the battery charge up.
  18. Blackwing
    Blackwing Member
    102
    I used it a few times to jump my BMW and family's Hyundai Santa Fe.
  19. Patrick Wong
    18,210
    6,517
    It is risky to use the Prius as the donor for a jump especially at the dedicated jump start point because the 120A MAIN fuse is inline and might be blown depending on the condition of the recipient vehicle. If you must use the Prius as donor, connect directly to the battery in the hatch, then you are only risking the battery itself.
    Not to mention the Prius battery is marginal at best and not intended to provide starting current for a traditional gasoline engine starter motor.
