2005 AC issue
Discussion in 'Gen 2 Prius Technical Discussion' started by Luiggie, Jun 26, 2017.
  1. Luiggie
    Luiggie Junior Member
    Puerto Rico
    Blower fan not working, the issue is intermitent. If I start to play with AC controls(On and Off) sometimes it start sometimes not, what I noticed is each time I click on button the blower start but within a second it stop and it did not reach the correct velocity.
    I replaced the fan blower yesterday and cabin filter and same issue. What else I have to check? Summer here and hot days also :(
    2005 Prius 141k miles
    iPhone ?
  2. JC91006
    16,933
    8,643
    You'll need to replace the fan blower controller, it's a small box that the fan blower connects to
  3. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    What JC91006 said!
    The blower fan controller is essentially the same as the Electronic Speed Controller (ESC) for a Remote Control model car, truck, plane, boat; it is also an analogue of the "blower motor resistor block" of yesteryear, albeit an electronic one. It take the blower speed demand signal from the Climate Control system (low voltage and low current) and applies voltage, but with a much higher amperage limit to the blower proportionally.
  4. Luiggie
    Puerto Rico
    Thanks!! Replaced fan blower controller and now AC is working fine!!
    iPhone ?
    valde3 and bisco like this.
  5. 1SteelerFan
    1SteelerFan Junior Member
    Tampa
    Check your blower resister
  6. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    Hi and welcome to PriusChat. You will notice in the above couple of posts that this problem was solved.
  7. Prius Mama
    Prius Mama New Member
    Fargo
    Was it hard to do? Think mine has same issue. Although it always blows out fine just doesn't get cool for while- takes few minutes and it's intermittent tho. Today I noticed that the left side was blowing little softer and room temperature but the two vents on the right were cool!
