2005 and 2006 prius 12v battery problems
Discussion in 'Gen 2 Prius Main Forum' started by Mike Thomas Bourque, Sep 30, 2017.
  1. Mike Thomas Bourque
    Mike Thomas Bourque New Member
    nashville tn
    i have 2 prius that have been parked for awhile and were only started once every two or tree weeks for the past year. so i came home ,they are both dead. the 2006 i boosted, it started runs fine but if its stopped for more than 1-2 hours its dead and wont start again.. need to re boost it (i havent had it running for more than an hour and did that twice, it started up fine after, but once it was turned off for a while it wont start, i did check and the battery reads 13.9 to 14 v on the prius screen.
    the other one will not go passed accesery when boosting mode and has a battery sign logo that says main on top left of screen, what could this be?
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Sounds like you are having 12v battery issues.
  3. dolj
    dolj Senior Member
    8,657
    4,407
    Wellington, New Zealand
    If this is with the car showing READY or just after switching off, then it doesn't really tell you much. Read the voltage at the battery using a voltmeter after the car has been off for at least 2 hours. if it is less than 12 V, replace the 12 V battery with a new one. If it is above 12 V use an automatic multi-stage battery charger with an AGM setting to charge it overnight or until the charger indicates it is fully charged. Wait 2 hours after disconnecting the charger, then test again. If the voltage is less than 12.4 V replace the 12 V battery.
    For this car, I would say that in addition to your 12 v battery dying, your HV battery may have self-discharged to the point the car can longer start. You will need to have the HV battery charged externally either at the dealer using their HV battery charger or by buying a grid charger such as the one sold by Hybrid Automotive. Just a guess, but retrieving the DTCs using a Prius aware scanner will give you a better idea on this one.
    There is fuel in the car, right?
    #3 dolj, Sep 30, 2017
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    You (most likely) have bigger problems than the 12v issues. Letting those old HV batteries sit unused for long periods of time is very bad for their lifespan.
    GOOD LUCK!
  5. Mike Thomas Bourque
    nashville tn
    So the 2006 (one that the 12v battery seems to be the only problem) seems like its just the 12v battery
    the 2005 (one that wouldnt go passed accessory mode ) it started when i first started it yester day left it on for awhile, only the engine ran, then i drove off, and i stopped to check something in the back, as soon as i pressed the "Park" button, it shut down completly, then when boosting it again wouldnt go passed accesory mode with the "battery sign, the little red light that looks like a 12v battery , on the top left corner of the screen )
  6. JC91006
    16,939
    8,647
    You would need to fully charge the batteries and load test them. Replace if necessary. This is the only solution
