2005 backseat door replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by barrystein, Feb 20, 2016.
  1. barrystein
    barrystein Junior Member
    26
    Oceanside, CA
    Smashed in the backseat door driver's side.
    Quoted $2000 at body shop.
    Is it an easy swap out if I find one at a junk yard?
  2. JC91006
    16,934
    8,644
    You can get a complete door for about $200 on craigslist....if that's all that's damaged
  3. barrystein
    26
    Oceanside, CA
    where can I find instructions on how to swap the old door for the new one?
  4. JC91006
    16,934
    8,644
    It's very easy, unbolt and disconnect wires......then bolt on new door and connect wires.
  5. barrystein
    26
    Oceanside, CA
    is their a video somewhere or pictures and instructions?
  6. JC91006
    16,934
    8,644
    If you find a door on craigslist, most likely that person selling can put on the door for you.
  7. jjmerp
    jjmerp Junior Member
    51
    22
    Ohio
  8. Mendel Leisk
    42,286
    What was the quote for exactly?
    One thing, if you find a door in your colour, get it installed and aligned correctly (alignment can be tricky), you'll very likely see an obvious transition, the paint will never match. When a body shop quotes $2000 it should entail repainting the panels adjacent to the damage as well: gradually thinning out the paint till they're spraying just clear. Done well, this'll be a seamless repair, unnoticeable.
    It depends on your tolerance, the age/condition of the car.
    #8 Mendel Leisk, Feb 20, 2016
  9. barrystein
    26
    Oceanside, CA
    The quote for $2000 was to put a new outside panel on the door and to repaint and blend in the pain to match
  10. JC91006
    16,934
    8,644
    What color is your car? which side back door do you need?
  11. barrystein
    26
    Oceanside, CA
    Driver's Side back door - I don't know if that is referred to as left or right..
    It is a medium to dark blue, where would I find the color number?
  12. JC91006
    16,934
    8,644
    this color?
  13. barrystein
    26
    Oceanside, CA
    yes, thank you
  14. JC91006
    16,934
    8,644
    You can find this door easily in the Los Angeles area craigslist. It's the seaside blue pearl color. I would think a complete door will be under $200. There isn't a lot of demand for this color door.
    05 Toyota Prius door / engine / mirrors
  15. barrystein
    26
    Oceanside, CA
    Thank you..... are there any videos online that show how to remove and replace the door.
  16. JC91006
    16,934
    8,644
    I don't know if there's a Prius specific video, but there are tons on youtube.com Just search "how to replace car door"
  17. Mark60
    Mark60 New Member
    Mocksville
    Thank you, found exact color left rear door replacement, yesterday and was contemplating having it done. I'll do it myself, now. What's the small black hook up for?
