2005 Battery worries at 136,000?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Earth Day Driver, Apr 22, 2018.
  1. Earth Day Driver
    Earth Day Driver New Member
    Seattle. WA
    Just got a 2005 Prius at 136,000 miles... should I worry about need to replace battery, and what kind of warning signs to look for? Are they as expensive to replace as I have read ($4000)?
  2. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Yes you should worry.
    HV Batteries last 10-15 years, 12v 4-6 years. HV Batteries can be replaced for a low as $1600 if DIY. 12v batteries cost $150-250 if DIY.
    Use the search function, there are some very good discussions on this topic.
    scona likes this.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I have to say, years seems more a concern than mileage. But your Prius is up there in years.
    Heat can shorten HV battery life, if the car was always a Western Washington car, it will not have seen much heat. To be honest Seattle does not have much of a 'Winter' either. Living close to the ocean, you may wish to inspect for corrosion.
    If the previous owner(s) had pets, you may wish to clean the battery ventilation system.
    Pictures of a dirty fan Prius battery cooling fan cleaning, P0A82 - Luscious Garage | Hybrid Specialists
    Crude video showing how to remove the fan
    kenoarto likes this.
    52,822
    congrats and welcome to priuschat!
    no point in worrying, but time to start investigating replacements while you're not under the gun.
    all the best!(y)
  5. kenoarto
    398
    Chicago, IL
    My guess is that 90% of 2005s are still working fine on their first batteries. But that is a total guess. Is there any definitive data on the lifetimes of Prius and/or their batteries?
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I think Consumer Reports said 1/2% failed each year, which would imply about 8% failure so far. But that is also not definitive. As Toyota will not know about out of warranty work, I doubt there is a better source.
