2005 - Brought Used Vehicle with Several Problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Xfiniti, Nov 19, 2015.
  1. JC91006
    16,904
    8,630
    The radiator flush was not a priority, there's no immediate issue with P1150, as this doesn't affect the car while it's running. Now with P1121 present, you may have to drain that radiator again to change the valve out. I guess if you have the right clamps, you can avoid the radiator flush by clamping off the hose while replacing the valve for P1121. Did your mechanic use the proper pink Toyota coolant?
    The main issue with your car is still the HV battery, the other issues are not as important or as expensive. P1121 will not cause your car to break down, but the HV battery failure will cause it to break down.
  2. Patrick Wong
    18,210
    6,515
    1. How well does the cabin heater work? Do you hear any air bubbling in the system?
    2. I am concerned that if the engine is in fact overheating, that may be due to air in the cylinder head.
    3. If you believe the engine coolant system does not have any air in it and P1121 is logged then it is time to change the engine coolant valve.
  3. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    Did Toyota tell you that you need a new HV battery? If not you need to get the proper Toyota tech stream obd2 reader. If you do need a new battery used batteries seem to be the best alternative if you're on budget. The big question that pops into my mind is "did you get a good deal on your car?" If you did than it's all good, if not you might want to consider small claims court or some other avenue. We have a local wrecker here that will sell used high mileage batteries for $300, low mileage for around a grand. It's not that difficult of a diy job from what I've seen...
  4. Xfiniti
    Xfiniti New Member
    New York, NY
    @JC91006
    I brought the Toyota coolant for the mechanic to use. If the pan I use to catch the new coolant inside is clean would I still have to buy new ones?
    I'm in the process of getting a new HV battery.
    @Patrick Wong
    1. The car sounds like an ICE car, I hear a roaring coming from the front when I accelerate or when it charges the battery when idle. It sounds nothing like my friend's (like a laser gun charging up).
    2. I'm not sure how well of a job the mechanic. They got pretty good reviews however.
    @Dino33ca
    I brought the car for $2,500 and I probably should've expected multiple problems with the vehicle other than what I was told.
    Thanks for the replies!
  5. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...sorry about that too bad, might have been better if the orig owner had made this request.
  6. Xfiniti
    Xfiniti New Member
    New York, NY
    Update:
    I was driving along the Williamsburg bridge and the red box with the thermometer in the water kept coming up and going away. It went away as I slowed down but came back after going over like 43 mph.
    I ran the scanner again and P1121 is gone. What??
  7. Patrick Wong
    18,210
    6,515
    1. The question #1 in my post #22 above needs to be answered.
    2. Now that you've driven the car a few times since the coolant was worked on, check the engine coolant level (at the radiator itself, do not rely upon looking at the overflow container.)
    3. I suggest that you do not drive the car extensively while this overheating problem persists.
  8. Xfiniti
    Xfiniti New Member
    New York, NY
    @Patrick Wong
    1. Sorry I didn't read the first line. The cabin heater worked really well after the radiator was flushed. The next day it was mediocre and now it barely works. It's just cold air coming out no matter how high I put it up to.
    2. Is the radiator cap the silver twist one under the plastic piece or the black cap? I get the two confused.
    3. Acknowledged
    As far as codes go, P1121 is gone now but P1116 popped up.
    Thanks for the help!
    #28 Xfiniti, Nov 22, 2015
  9. Patrick Wong
    18,210
    6,515
    1. The engine coolant loop most likely has substantial air in it if the cabin heater is not working now.
    2. Yes, you are looking for the silver twist cap and need to remove the large black plastic cover over the radiator for access to the radiator cap. See how much air is in the radiator now.
    DTC P1116 is related to P1121 and means that the coolant heat recovery system temp sensor at the CHRS canister is not registering the correct temperature value changes as the system operates. This is probably related to trapped air in the system.
    I have previously posted on how to change the engine coolant and purge the coolant system. See my posts #22 and #42 here:
    Changing engine coolant | Page 2 | PriusChat
    You may want to follow my instructions about how to do this since it seems that your mechanic did not do a complete job. Make sure that the pink Toyota Super Long Life Coolant was used. If this coolant was not used, that is more evidence the mechanic took shortcuts.
  10. Xfiniti
    Xfiniti New Member
    New York, NY
    @Patrick Wong @JC91006
    I took the car to Toyota and it turns out, the car has mich more problems than expected. To summarize, the problems Toyota found dwarfed the problems I was able to find with the scanner. I was quoted $14k-$15k in repairs, and that's not including what we were discussing here. I'm currently working something out with the seller right now.
    Through some family connections, I was able to get myself a 2015 Prius V (not without having to pay them back later of course).
    I would just like to thank you all for the help and support. This is a great community and I look foward to interacting with you guys on another part of this forum.
  11. JC91006
    16,904
    8,630
    This might be a record amount for repair quote on a prius. I can't even begin to imagine what can cost that much money on a car that still runs, but has issues.
    valde3 likes this.
  12. ericbecky
    ericbecky Hybrid Battery Hero
    4,450
    3,358
    Madison, Wisconsin
    Sounds like the repair estimate included, "Buy new car from our Sales Department".
    Seriously, though, I'd love to see the printout of the estimate.
    (personal info edited out, of course)
