2005 Check Engine light on- only owned for 4 days! :(
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Brown, Jul 17, 2009.
  1. ggcc
    ggcc Member
    132
    Bay Area, CA
    2014 Prius Plug-in
    Totally agree with you.:D
    I think if we can afford the new then new one is always better. However, we also should own used one too so we would know both sides.
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Yes usually a buyer should get about 3 month worth of warranty from a used car dealer.
  3. vertex
    vertex Active Member
    673
    144
    new york
    2018 Prius Prime
    I would guess that since you were driving up a long steep hill, the engine overheated. I know from first hand experience that if the Prius ICE is running hard for a while it will overheat. The cooling system is not designed for the ICE to be running for long periods. Since the triangle disappeared, and the CEL is still on, I would confirm that you have sufficient coolant in both the ICE radiator and the inverter overflow tank. If the ICE coolant level is low, then the engine probably overheated. If the car appears to run properly except for the CEL, I would carefully drive it for a few miles. If nothing happens, I would feel comfortable driving the car. The CEL will clear after 3 trips if the problem went away. I overheated the ICE in my Prius several times while I was trying to repair other problems (from an accident). Once the engine cools down, and coolant is topped off, the car will run fine. Since the car overheated hill climbing it may need a radiator flush. You should get yourself a scantool to read the error codes. That would give you peace of mind in the future if the CEL goes on. At least you will know if the problem is serious or not.
    Good luck!
  4. Brown
    Brown New Member
    western nc
    Drove car to work today. Light went off. Was happy. Proceeded with life as normal. Light came back on with the lovely "problem" notice on the screen. Drove to AutoZone. Got code P0A93. Called dealer where I purchased the vehicle and spoke to very rude service rep who said that he had never heard of this code and that they "do not have problems with their inverters." He acted like I was a complete idiot and insisted that I bring it to a dealer. Currently searching for someone who is less rude and more helpful who can actually fix the dang thing.
    At this point I'm concerned that the car was traded in with this problem and that I'm going have an even bigger problem.
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    According to my data, P0A93 has two DTC values, 346 and 347. Both point to "Inverter Cooling System Performance"
    DTC 346 is most likely a failed inverter cooling pump. The suggested diagnostics are:
    - Wire harness or connector
    - Inverter cooling system (Eg, low coolant, leak, air in system, etc)
    - Inverter cooling pump
    - Cooling fan motor
    - Cooling fan motor 2
    - The scary one: the inverter/converter assembly
    There is a TSB for earlier Prius cars involving a defect in the inverter assembly. Not sure if it applies to your Prius, a dealership should be able to check the VIN and tell you
    Sounds like a real dickhead
    However, if this is a Toyota dealership, they should be very well aware of this issue. I wouldn't bluff it off, and do NOT keep driving the car in this condition. If the inverter cooling pump is kaput (Figure on $400-$500 if you have to pay for it out of pocket), you could potentially fry several thousand dollars worth of components
    2 people like this.
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    If the coolant got too low, there could be air in the inverter system. Most likely, with a 2005 Prius, the inverter electric coolant pump has failed. You do NOT want to keep driving the car in that condition, you WILL fry the inverter!
    Consider booking an appointment with that dealer, drive during a cool time of the day eg early morning, no A/C use. Consider stopping every 15 mins of so, pop the hood, let things cool off
    Now, at that dealership, inform them you want the codes read, but do NOT agree to any work without written authorization from you. They sound like real beauts, do NOT agree to anything unless you have a firm price IN WRITING
    Even for diagnostics, they may ding you $100 if they are real a**holes. However, that is still cheaper than a +$3,500 inverter assembly
    Do not keep driving the car in this condition. It will become expensive in a hurry. Consider calling the Toyota customer service number and complaining
  7. 2009Prius
    2,705
    512
    63
    The seller should fix the problem for you. Or was the car bought "as is"?
  8. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    Ditto, take it back like yesterday!
  9. icarus
    icarus Senior Member
    4,884
    976
    earth
    I'm sorry,, but this is just BS. The cooling system of the ICE is just as robust and in fact more so than any other vehicle. The car may have over heated,, but not because "the cooling system is not designed for running for long periods"!!!!
    I have driven the Prius for 40k miles mostly in the mountainous west,, but also the mountainous east and every hill in between. I just drove up the Vantage hill from the Columibia River in Vantage WA to Ryegrass summit. The longest unbroken, continuous grade west of the MS River in +100f heat. The temp never registered over 208f,, with the A/C blowing away.
    Clearly, there is something wrong beside "bad design" Let's not perpetuate bad stereotypes about Hybrids!
    Icarus
  10. vertex
    673
    144
    new york
    2018 Prius Prime
    It is NOT BS. You get that engine going at 4K rpm for 15 minutes straight, and it will overheat, even on a cool day. The challenge for you is to get it to run at 4K+ RPM for that long. It happened to me 3 times until I fixed the TPS adjustment. Instead of doing a fuel cut, the engine starts screaming. Now it runs just like yours!
    Clearly, knowing the codes he got, It is an inverter problem. But I seriously doubt if overheating it will cause it to fail. The inverter is protected, and should turn off if it gets too hot. No good EE would let his circuits fry from overheating!:)
  11. vertex
    673
    144
    new york
    2018 Prius Prime
    Forgot to mention, you can tell by looking in the overflow container if the pump is working. You can see the fluid moving by looking at the surface of the coolant. You can see a disturbance at the inlet. You can compare how it looks with the car off and on.
  12. icarus
    4,884
    976
    earth
    I'm not going to get into a pissing contest about this,, but first go back to the original post,, and there is no mention of a 15 minute hill. Second,, even the Vantage hill I mention above,, wouldn't require a run of +4000 rpm for 15 minutes. I personally don't know of a grade in N. America that would be that steep for that long.
    Finally, with a scan gauge, I have never seen the coolant temp rise about ~208 f even with OATs of +100f.
    Now I will concede that inverter temps are another matter, and not one that I can comment on, since a scan gauge doesn't register inverter coolant temp.
    I stand by my opinion that " The cooling system is not designed for the ICE to be running for long periods." is patently false. This however doesn't mean that there are cases of Prius' overheating. Any car can overheat given the right (wrong) set of circumstances, but to infer that the Prius is not designed for long periods of operation is just plain wrong.
    Icarus
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    True, but a lot of "excursions" into the red zone tend to impact MTBF, and can cause glitches. As our resident mad scientist Hobbit discovered,
    http://priuschat.com/forums/gen-ii-prius-technical-discussion/65037-how-critical-inverter-pump.html
    as long as the inverter case isn't too heat-soaked, it will actually remain fairly well protected even without the pump running.
    But if her pump is kaput, it needs to be changed
  14. Brown
    Brown New Member
    western nc
    Bought "as is" so it's technically my problem to deal with.
    However, this is the second car we've purchased from this dealer within the last 2 months and both vehicles now have issues. Combining this fact with the jerk in the service department who said there was no problem, I've certainly been spending time on the phone yelling at people and can't wait to get my customer satisfaction survey and call back from the manager.
    At any rate, I'm planning on a very slow journey with many stops to the nearest dealer today to see if I can get all this resolved. Will update on actual problem and solution.
  15. 2009Prius
    2,705
    512
    63
    Two bad cars in a row is outrageous even if sold "as is" in my opinion. :mad: If I were you I would get help from the Attorney General's Office in your state ASAP. They should have consumer protection program/department you can get help from. Good luck! :)
  16. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    In addition, do not buy cars from this dealer ever again. If they won't give you at LEAST a 30 day warranty on ANY used car, they aren't checking out the cars they sell. "As is" is usually reserved for private sales where the seller may not have the ability to check all systems. In that case, you can only hope they are honest about revealing any problems. And ANY time you buy a used car, take it to a trusted mechanic for a through look over BEFORE you buy it.
  17. vertex
    673
    144
    new york
    2018 Prius Prime
    Icarus:
    I think maybe I wasn't clear. Under normal operating conditions, the engine will not overheat. My experience is that if the engine is running at high RPM for extended periods that it will overheat. Of course the Prius will not be stressed like that unless you are climbing Mt. Washington at a good clip. (Anyone done that in a Prius?) I only mentioned this because the symptoms are similar to overheating, and a long hill climb was mentioned.
    Howard
  18. nagrath
    nagrath Member
    145
    49
    Putnam County, New York
    2023 Prius Prime
    XSE
    Did you suffer any brake failure? Did the ABS light also come on? This happened to me on my 2005 (and has happened to others) from a failure in the skid control ECU and the brake actuator. Toyota, after I complained mightily, fixed it under warranty, but that was still in my 3/30 warranty period. I would definitely contact the dealer and complain.
    John
  19. jswalt2
    jswalt2 Junior Member
    Not that this will help you make a decsion but two weeks ago my 06 prius had the same lights come on. I drove it about 14 miles, by the time I got to the dealer the battery was low and not re-charging.
    The dealer said they had to replace the computer and the battery!
    $5000. They paid as I had an extended warrenty.
    They said it was a rare thing to happen.
    I complained to myself but my wife had the best outlook. We now have a 06 with a brand new computer and battery. they even rented me a car while the prius was being repaired.
    I think I would go for the extended warrenty again.
  20. Brown
    Brown New Member
    western nc
    No one will be shocked to know that it was the inverter coolant pump causing the issues. The replacement should be here Friday and I will be up and running again hopefully, problem free.
    Thanks for all the comments and help from everyone.
    It was nice to walk into a service dept and actually have some sort of a grasp on what was wrong.
