2005 Dead Hybrid Battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Holly1212, Nov 8, 2014.
  1. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    Given the price differential of $300 for a genuine Toyota brand new pack, I'd save up the extra $300 and get the genuine Toyota pack every time. No more battery worries for at least 10 years.
  2. Holly1212
    Holly1212 New Member
    Westminster, CA
    There's also tax to be considered since in CA we get taxed for everything. Also, I noticed that the cheapest battery available from San Bern is picked up only and it is pretty far from where I live. So far, all my calling around to local mechanics yield me
    option 1: A new Dorman battery for $2370 including labor with two years warranty (I thought dorman only has rebuilt batteries?)
    option 2: Some other refurbished battery for a total of $2444 (Labor + car rental was $500)
    option 3: Brand new toyota battery for $2800 including labor ($2329.80 for the battery and labor was $340)
    option 4: Rebuilt Dorman battery with 2 years warranty ($2260.39 for battery and about $200 for labor) They said they called Toyota for a new battery, but their Toyota dealer only had remanufactured battery for about the same price as the Dorman.
    I am hoping to find a used but original Toyota battery salvage from another Prius since I find it difficult to spend so much money on one part when in the future, some other expensive repair might occur. Anyways, does anyone know if it would be possible for me to drive my prius in this condition 10 miles round trip for work for a few days?
    #22 Holly1212, Nov 11, 2014
  3. writes123
    writes123 Junior Member
    92
    23
    Riverside, CA
    I'm not sure how involved a pickup of a new HV battery is but I might be able to assist as I live in Riverside, about 20 mins from San Bernadino Toyota.
    Holly1212 likes this.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    ^^ Very kind of you.
    Regarding a new battery, the more important question to sort out is the installation. The old battery has to be removed from the car, the electronics and ECU switched over to the new battery, and then the case reinstalled.
    Even with shopping around this is going to cost $2500 easy when all is said and done. OTOH it is likely to be a much longer lasting repair than the reman route -- I'd figure three times longer. So long as Holly plans to keep the car long term I think this is a pretty easy choice.
  5. JC91006
    16,936
    8,647
    Although it is very kind of writes123 to offer his help, I'm not really sure she should trust someone she doesn't know to bring her a $2000 battery.
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    I've read through your post. Bummer about the craigslist battery. I can send a replacement (refurbished) battery and help you through installing it for just under $1,900. 3 year warranty.
    I am an independent hybrid mechanic who has worked on hybrids for over 10 years.
    I have run the local hybrid car club for over a decade and provide outreach education about hybrids as well.
    I think you are on the right track for making a decision. Call me if you want to talk through things even if you don't plan on buying through my shop. I'm happy to help.
    608-729-4082
  7. Holly1212
    Westminster, CA
    Thank you very much for your offer, but I can't possibly bother you for such a big inconvenience. I've updated my list of options above with more details for anyone in the future with the same problem can compare. I've also went to the mechanic yesterday after all my calling around and had a print out of all the error codes that showed up.
    P0A80 Hybrid Battery
    P0203 Injector Circuit/Open-Cylinder 3
    C1271-C1274 Low output voltage of right/left front/rear speed sensor
    So my mechanic told me that basically a bunch of ABS codes showed up, but he thinks it might be because of the hybrid battery.
  8. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    We are 27 messages into this thread and I don't have time to go back and review but if you have not tested or replaced the 12V battery and had it's charging voltage tested, you probably should do that FIRST. Cost will be $200 or less and it might just clear up most of the codes.......long shot though.
  9. Logangogarty
    Logangogarty Junior Member
    31
    I haven't read through this thread but I had to inform everyone about this guy Prius Hybrid Battery Rebuild Replacement He came to my house (San Antonio) and fixed my battery for $900. He pulls out the dead battery takes it to his shop and refurbishes by draining all the fluids and replacing them. Then he places it in the next persons car who has a dead battery. The car has been running much better for the last 7 months since he did that. He will drive to a lot of places and is very knowledgeable about the prius. Anyways go to the website and contact him he did amazing work and was super helpful.
  10. JC91006
    16,936
    8,647
    "draining all the fluids", did he tell you this was his process?
  11. Logangogarty
    31
    No I think he actually said he runs something through it. I'm not exactly sure. The way he made it sound was he hooks it up to a computer to see exactly whats wrong with it like what cells are bad etc. and then he runs something through it. I'm not sure about his process I just know that for my car it has worked very well.
  12. Logangogarty
    31
    Here this is from his website. I know the site looks a little sketchy but I really think he is an honest good mechanic
    If you live anywhere in TX you are qualified to have your Prius 04-12 bad hybrid battery replaced with a complete rebuilt hybrid battery pack using
    (28) Completely re manufactured Nickel Metal Hydride (NiMH) Battery modules with
    12 month unlimited miles warranty installed free with our mobile service 24/7 anywhere in TEXAS.
    We have a passion to serve all our Texas customers and to help them stay on the road saving lots of money on gas!!! Our customers refer their friends and neighbors to us and this is how we get most of our business!!
  13. JC91006
    16,936
    8,647
    Most people are quite happy with their batteries right after they are replaced by a "rebuild". However about 3 or 4 months later, their happiness usually turns to anger and frustration. With the age of the GenII cars now (10 years old on 2004 models), most of those "good" modules aren't really "good" for long.
  14. Logangogarty
    31
    I'm at 8 months so far and things are going well. I will let everyone know if things change
  15. JC91006
    16,936
    8,647
    Also their warranty, that's where the anger and frustration comes in. They like using the line "the warranty only applies to the modules we replaced" not the ones (27 others) that we didn't replace.
  16. dolj
    dolj Senior Member
    8,645
    4,395
    Which I think is fair enough as long as it is clearly disclosed. After all, how could they, in all reality, warrant something of unknown condition?
  17. JC91006
    16,936
    8,647
    A rebuilt should be tested and rebalanced, all the modules should be equal after rebuild. Most are just doing fast module swaps and calling it a rebuilt. it's hard finding the people that rebuild them properly, not too many of them around.
    It's crazy to just only warranty the replaced module and not the entire pack
  18. SageBrush
    11,627
    2,533
    Southwest Colorado
    The rebuild is supposed to swap out the bad modules, implying they checked all 28 and left the good ones. If that is the case, then why have a problem with a warranty that covers the entire pack ?
    The answer, unfortunately, is as JC posts: the rebuild is crap.
  19. Logangogarty
    31
    On his website he says "using (28) Completely re manufactured Nickel Metal Hydride (NiMH) Battery modules" so it sounds like he replaces or fixes all of them who knows if this is actually the case.
  20. JC91006
    16,936
    8,647
    Well yours is going strong, that's a good sign
