2005 Dr. Prius/Hybrid Results. Prolong?
Discussion in 'Gen 2 Prius Technical Discussion' started by Kirk05Prius, Mar 19, 2021.
  1. Kirk05Prius
    Kirk05Prius Junior Member
    Peoria Illinois
    Screenshot_20210319_053848.jpg Screenshot_20210319_053720.jpg Long time lurker. 1st time poster.
    Bought 2005 prius with 140k in 2017. Drove Uber. Love my Prius. Just put a hitch on to tow a very small camper. (after lots of reading on here)
    Now have 205k miles. I don't know if it's the original traction battery. Also unsure how old the 12 volt is.
    My mileage at best is 42 mpg. I've never seen it do much over 42 mpg in the 4 years I've owned the car. 50 & 60 mpg are the advertised mpg. Mileage hasn't noticeably changed.
    I bought an OBD sensor & used Dr. Prius said:
    Weak block detected
    Poor balance block 1
    49.63% capacity
    No battery warning lights have ever come on.
    I plan to drive my Prius if I could for another 10 years til i can buy a 10 year old used hybrid sienna :)
    Cheapest way to get my Prius to last 10 more years?
    Prolong is $750. I'm comfortable with a buddy's help installing. I'm not comfortable pulling & replacing cells. I'm in Peoria Illinois if ne1 has one to rent. I guess i could rent it out to get back some of $750.
    I don't want to pay $3k for new battery from dealer. But maybe best long term option?
    Refurb seems to run $1,500.
    Any advice or insight other options appreciated.
    52,803
    'newpriusbatteries.com'
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    alftoy, Kirk05Prius and fotomoto like this.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    You want a new battery then. $1600 on up. And keep a repair fund for other big ticket items.
    IMO, it’s way too late to start grid charging a nearly 17 year old battery (if OEM).
    GOOD LUCK!
    alftoy, Kirk05Prius and edthefox5 like this.
  5. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    What SFO posted. DIY charger simple as above or more complicated linked.
    V2-grid-charger-discharger MOD Note this is for a Honda Insight, note changes to make for Prius
    OlRowdy01 V2 Grid Charger Build (Illustrated) | Honda Insight Forum
    Modified as noted in attached pdf for 2004-2009 Prius, HLG-80H and 4 bit 500vdc 10 amp meter
    As fotomoto mentioned, way too late to start grid charging a nearly 17 year old battery (if OEM), if that is something you want to try, build your own for less than $100.
    #5 alftoy, Mar 19, 2021
    SFO likes this.
  6. Kirk05Prius
    Peoria Illinois
    Looks interesting for $1600. But self install. I can do some stupid stuff so not sure I'm safe enough to deal with the battery.
    Thanks for the warm welcome.
    Thanks to all the good info on here I did have the transmission fluid replaced when i decided to do a small amount of towing.
    I'll work through the other links. Thanks for great info.
    My chevy prizm has 320k miles. It's been my science experiment.
    I really want to see what effect grid charging would have on such an old battery. (probably just fail a bunch of cells!). My next science experiment.
    New battery is probably best way to go. & if I'm road tripping & towing..... But i really want to see that battery brought back to life. But i really don't want to break down with a trailer behind.
    #6 Kirk05Prius, Mar 19, 2021
  7. Kirk05Prius
    Peoria Illinois
    @alftoy
    Thanks for good info. After a reading some of the links, I'm not handy enough to build my own :)
  8. dolj
    dolj Senior Member
    8,633
    4,388
    Wellington, New Zealand
    You can't really. The best you could ideally hope for is to extend this battery for another 2 -3 years, but as this battery is already giving signs of failure that ship (preemptive maintenance) has probably already sailed. Save your money and put it towards a new battery, which given your goals, is your only option. If you have to rely on someone else to install it, it will cost more than DIY.
  9. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    Post screenshots of the actual battery data so we can take a look at those. I think you can tell more from that data then the “battery life test” since that’s basically just a capacity test.
    Prodigyplace likes this.
  10. fotomoto
    5,639
    3,815
    So. Texas
    Check out the link in my signature. If you're not DIY enough to install a new battery, why would you be DIY enough to install a grid charger and play the wack-a-mole game? It takes about the same level of, umm. DIY-ability. LOL
  11. twc
    twc Junior Member
    MI
    Not sure if ok to ask on this thread, but could you tell us which camper you bought, hitch, and how it's working out for you?
    Thank you! God bless you all.
