2005 DTC P0A80 Diagnosis
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Eeyore, Jan 12, 2018.
  1. Eeyore
    Eeyore Junior Member
    Salem Oregon
    Hello all, new member here.
    My 2005 Prius gave me some errors this week. After a short trip of about 20 miles, the HV battery was acting a bit strange towards the end. I noticed it drained and charged rapidly the last couple miles. I'm the span of a few blocks in a residential area before the end of my first trip it went from 1 bar to completely full. The car sat for roughly 20 minutes before setting off again. About 1 mile later, the Matter Warning Light, Check Engine Light, the yellow (!) light, and the VSC light popped up on the dash. "Problem" was then displayed on the multifunction display and the info panel shows a red car with a ! in the center of it. I immediately pulled into an AutoZone parking lot that was conveniently next to me. I had an employee check the codes and 12V battery. No codes could be read, so I assumed his scanner wasn't able to read Toyota codes. There 12V battery read 12.3V with the car off and tested in good condition. I then called my local Toyota dealership. Their mechanic said the car should be fine to drive to their location as there was no difference in performance. I chose to park it and troubleshoot it myself, seeing as I am an Electronics Engineering Technician. When I arrived home, 20 miles from point of incident, the car drive flawlessly. No extra noises, change in power, breaking force, or anything in the smallest manner that would hint at an issue. The HV battery did read some odd numbers when driving under electric power only.
    After parking the car, I turned it off, then on again. The VSC and (!) Lights disappeared. The HV battery does seem to drain and fill rapidly and randomly some of the time.
    I read many posts on this forum and others about similar issues. I then purchased an OBDII Bluetooth adapter and the Torque Pro app to check the block voltages of the HV battery and read the DTC codes. I noticed that the majority of blocks were reading 17.7V, a few were at 17.6V, and 2 were at 17.2V (block 1 and 14). The fault chose came back with P0A80, signaling the hybrid battery needs to be replaced.
    So, am I correct in assuming that blocks 1 and 14 are at fault? If so, should I balance them, or replace them?
    This should be a factory replacement battery from Toyota. The previous owner informed us that the HV battery was replaced roughly around 150K miles. The vehicle currently has 230K miles. We live in Salem Oregon, so heat isn't an issue.
    Original errors:
    After driving back home and restarting the car:
    After letting the car run for 5-10 minutes:
    After "force charging" the battery:
  2. JC91006
    16,936
    8,647
    You can log onto the Toyota website and check the service records. See if there's a battery replacement around 150k miles.
    Premature failures happen, but it's very unlikely
  3. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    You're right about the two blocks that are showing below 17volts. In my opinion, they're weak, and if you've hot a prolog charger, you could cycle the pack at once, or get dome hubby chargers to do em. But you sure need to replace those two weak modules.
    PS: As you work on the pack, carefully inspect the voltage sense connectors and wires for corrosion
    #3 Dxta, Jan 12, 2018
  4. JC91006
    16,936
    8,647
    Blocks 1 and 14 usually look like that. They are not in line with the rest. It does not necessarily mean they are bad.
    P0a80 could point to ecu, which is usually not replaced with new battery
  5. Eeyore
    Salem Oregon
    I checked the service records and there is no recorded replacement of the HV battery by Toyota. Considering this information, I'm not sure if there battery has ever been replaced. If it was, then it was not through Toyota. How would I go about testing the ECU for faults? And what part number is that?
  6. JC91006
    16,936
    8,647
    If there's no records from Toyota on the replacement, then the code most likely means the battery is bad again. Not related to ECU
    Let the car sit a week and take another voltage reading, you should be able to identify the bad block
  7. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I don't think its your ECU that's the problem.
    The code is related to your HV battery pack being weak.
    There's a different code for the ECU
    Grid charge the pack, or disassemble it, and cycle the modules, after getting replacement ones from eBay or anyone over here.
  8. Eeyore
    Salem Oregon
    Thanks for the replies! I really hope it's not the ECU...
    My college has its own hybrid battery reconditioning equipment and the automotive department owes me some favors. I'm going to try to balance the low blocks before purchasing new ones. I found a seller on Amazon that has them for $37 each and they even offer prime shipping.
  9. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I don't think its the ECU from your codes.
    Get the two bad modules and cycle them, then you've to do same for the rest
    But if you've got no time, then a whack a mole approach, just maybe if you're lucky, might work.
  10. Eeyore
    Salem Oregon
    Would cycling all the batteries be worth it?
  11. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    I agree with @JC91006 about Blocks 1 and 14. Our 2007 has shown the same pattern since I first started using Torque Pro a year and a half ago, and the car has never thrown a code. I would check for corrosion first and then balance using the reconditioning equipment before buying replacement modules. You may not need them.
  12. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Depends on your time, and chargers you've got.
  13. Eeyore
    Salem Oregon
    I've watched the voltages and block one swings out by 500mV.
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Are you able adjust your torque display to show internal resistance of each block? That would more than likely help show which block is creating issues for you. Just another data point to verify where the problem is, prior to pulling the pack. And a P0A80 can be caused by the HV Battery ECU. This is the ecu that is installed in the battery pack, not the car.
    SFO likes this.
  15. Eeyore
    Salem Oregon
    I did watch the internal resistance. Everything was the same.
  16. strawbrad
    953
    1,007
    You want to look at the data while doing a forced charge, not after.
    A forced charge is just half the test. Run a forced discharge also. Add battery current to the Torque display. To run a forced discharge first warm up the gasoline engine so that it can remain off while testing. Turn on the headlights, high beams, and rear defroster. Put the car in reverse and give it some gas but not enough to start the engine. If it's warm out you can also run the AC on max cold. The goal is to put as large a load on the battery as possible. Within a minute or two the voltage of the weak module block will drop off. Codes are set when the voltage difference is 1.2 to 1.3 volts. Usually the discharge test shows the weak blocks more clearly than the forced charge.
    I agree with JC9106 that blocks 1 and 14 often read lower than the rest. The spread on yours is larger than normal.
    Brad
    m.wynn, SFO and Raytheeagle like this.
  17. Eeyore
    Salem Oregon
    So I have an extra 2005 Prius with a blown engine. It has a refurbished HV battery. The car has been sitting for a year or so. Can I just swap the packs between the two cars?
  18. Prodigyplace
    12,713
    11,848
    Central Virginia
    You could, but a refurbished (used) HV battery that has been sitting for a year may have issues too.
    Refurbished batteries have not had a good track record for reliability here.
    Raytheeagle likes this.
  19. Eeyore
    Salem Oregon
    It was running reliably before the engine blew. It was my sister-in-law's car.
    What about the ECU? Can I simply swap the two to rule out or confirm my ECU is toast/good.
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
