2005 DTC P0A80 Diagnosis
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Eeyore, Jan 12, 2018.
  1. Eeyore
    Eeyore Junior Member
    Salem Oregon
    For clarification, is the ECU being talked about the "Battery Smart Unit?"
    52,755
    any corrosion inside the battery case, buss bars and etc?
  3. Eeyore
    Salem Oregon
    I haven't torn the housing down just yet. I'm thinking about taking it to Toyota to read the 3 digit sub code before I dig into my own troubleshooting.
    52,755
    sounds like a good idea.
    Raytheeagle likes this.
  5. Eeyore
    Salem Oregon
    Does anyone know if I would have to pre-charge (or balance) the battery pack of my second Prius before installation? (If it turns out to be the HV battery)
  6. bisco
    52,755
    depends on the pack. is it new from toyota? if not, you should probably recondition it.
  7. Eeyore
    Salem Oregon
    It's a refurbished pack from my sister-in-law's 2005 with a blown engine. It's been sitting for a year.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Charge and balance it, that will give it the best chance;).
    But this is not guarantee :(.
    Good luck and keep us posted (y).
    JC91006 and bisco like this.
  9. bisco
    52,755
    over 6 months can be bad. you can try it, but it would be prudent to recondition first. if you install it and it works, it won't get better from driving like the reconditioner.
  10. JC91006
    16,930
    8,640
    You would need to put that battery on a charger before installing it. A 13 year old battery would not work properly after sitting a year, it'll be out of balance
    m.wynn and Raytheeagle like this.
  11. Eeyore
    Salem Oregon
    Thanks for the info! I'll take it to Toyota for confirmation. I'm going to then take it to my department and have both battery packs balanced.
    Where is the HV ECU located? Is it the Smart Unit or the one located in the dash?
  12. JC91006
    16,930
    8,640
    You don't have to mess with the battery ecu, they rarely go bad. But it's located on the battery pack. It's the rectangular box
    m.wynn, valde3 and Raytheeagle like this.
  13. Eeyore
    Salem Oregon
    I took it to the local Toyota service center and they said it's the battery. I concur with their diagnosis, seeing as the car went into limp mode at the light just before their driveway.
    I was watching the Torque app the entire 10 mile drive. Everything started out perfectly fine. I did notice that the resistance of blocks 1 and 14 were slightly lower than the rest. Under load, the end blocks were 500mV to 800mV lower than the center blocks. When the car went into limp mode, the battery fan kicked on for the first time in the 2 years we've owned it, and block 8 dropped an entire volt lower than the others. After seeing this, I think it's been block 8 the entire time causing errors. While at a stop, block 8 would steadily drop by 100mV every few seconds. I had to keep it above 17V, otherwise it would drastically drop lower than the others...
    Now here's the thing, I don't have a ton of money for the repairs, and this car literally costs half as much to run than my other. What should I do? I have a spare 2005 Prius with a blown engine (possibly inverter as well) and a refurbished battery pack that was working perfectly. The spare has been sitting for a year. Do I replace the individual batteries on MY pack, or charge the refurb pack, and how would I do that my self? I don't have access to my schools reconditioning equipment anymore.
    #33 Eeyore, Jan 22, 2018
  14. bisco
    52,755
    you can buy a hobby charger and do one module at a time.
  15. Eeyore
    Salem Oregon
    Can anyone recommend a cheap charger and a method of discharge?
  16. Eeyore
    Salem Oregon
    I was looking at the IMAX B6AC V2 charger for conditioning my pack. How many would I need to get to do this in about a week or two?
  17. Eeyore
    Salem Oregon
    Anyone?
    Would 4 be enough to charge my extra pack that's been sitting flat for a year?
  18. Michael Cyr
    Michael Cyr Junior Member
    Belgrade, ME
    Just for anyone else thinking about the IMAX B6AC V2. Don't. I have one for my drone and it can only discharge at about .7amp. It also doesn't seem to have a max NIMH voltage cutoff so I use the mAmp/hr cutoff.
