2005 engine light, deceleration, and stopped
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Over100k, Oct 26, 2016.
  1. Over100k
    Over100k Junior Member
    22
    Huntsville, Al
    My 2005 car is on the back of a tow truck. Background- I just got an oil change and tires rotated Thursday. No problems. This evening after driving about 12 miles, the tri engine light came on. I tried to get 1/2 mile to the gas station, but the car decelerated and stopped. I have anout 142 k miles on it. Everything was closed tonight so the driver will deliver the car to the dealer in the morning. I am new to this area and I have little confidence in the work at the dealership. I think they overcharged me for the last work.
    My question- what might be the problem and what questions should I have for the dealer? Any idea of how much a repair might cost?
  2. JC91006
    16,939
    8,647
    The dealer you are going to will figure this out for you.
    A guess would be the inverter coolant pump quit and the car overheated. If this were the case, the repair will be about $500
    If this ends up being a problem with the oil change, you can bill the people that did that service for the repairs
    SM-N900P ?
    #2 JC91006, Oct 27, 2016
  3. Over100k
    22
    Huntsville, Al
    Thank you, JC. I like having some clue of what the reasonable problems might be before the discussions begin. I will post back with an update that might help someone else.
  4. Over100k
    22
    Huntsville, Al
    The problem seems to have been an obstruction in the fuel rail. That set me back $200 for about 2.5 hours of diagnostic time. They siuggested that I use better fuel; which I feel I have been doing.
    #4 Over100k, Oct 28, 2016
  5. bisco
    52,891
    that happened on my brand new lawn mower. cost me 50 bucks, but i find it hard to believe. use mobil, but they claim it can't be more than a month old.
  6. JC91006
    16,939
    8,647
    Save your receipt, this sounds like it'll happen again. They don't fix themselves....You normally would get other symptoms first...like engine misfire. Not straight to engine shutdown
  7. Over100k
    22
    Huntsville, Al
    I am with you on that. I am very skeptical - but- the car is fine now, and your lawnmower too, it seems.
  8. bisco
    52,891
    yes, they claim they cleaned the carb, drained the tank and put in fresh fuel. i've never had it happen before, but i suppose anything is possible.
  9. Over100k
    22
    Huntsville, Al
    It is all too weird. The car just locked down say within 3 min of flashing lights. And I am careful where I buy gas. Anyway, I took my receipt to the company and filed a request for them to pay the bill. That likely will not happen, but I just needed to do that.
    Yes, I will keep the receipt. Thanks. While they had it they asked to change out the original spark plugs and I agreed. I almost wish I had kept them.
  10. Over100k
    22
    Huntsville, Al
    Well it seems that my fuel should have been drained and replaced as well if that is truly the problem.
  11. Over100k
    22
    Huntsville, Al
    They replaced the coolant pump about 6 months ago.
  12. bisco
    52,891
    you didn't do the 120k maintenance?
  13. Over100k
    22
    Huntsville, Al
    Hmmmmm- I don't think so. I guess spark plugs would have been changed out then? Well I guess they served me well. I am surprised my dealer did not pull my coattail on that one. I will look at my records.
