2005 FIXING The Loose Steering Play, At-Times
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius_Angie, Mar 28, 2018.
  1. Prius_Angie
    Prius_Angie Active Member
    245
    229
    Saint Louis
    P_20170420_141106.jpg P_20170416_102457.jpg OK as my 2005 Prius nears 260,000 miles several items have been in need of replacement, to include a $7 replacement intermediate drive shaft that I retrieved from a local junkyard. Symptoms were primarily loose intermittent steering that would only show up every other day; wheels were fine with straight handling. Over the past year I had already replaced many steering system items that I knew were not involved: shock struts, wheel bearings, new tires, brake & rotors, sway bar links, control arm, etc. In investigating the problem, I started at the top with the steering wheel and went down to the upper/intermediate/lower steering shaft. That’s when I discovered the loose play in the intermediate steering shaft.
    1. DISCONNECT BATTERY. First disconnect neg terminal to 12V battery. This will hedge off any inadvertent airbag deployments while playing around the steering column.
    2. ACCESS SIDE STEERING COLUMN AREA. With pry tool I popped off plastic pieces to driver side lower dash. Also the hood latch release lever needed to be released. Removing the underside dash gave me access and visibility to the bolts for both the upper and intermediate steering shafts. The picture shows I took apart the steering wheel, but you would not need it off for this procedure. Also while opened I wiped clean the driver side vent.
    P_20180303_171002.jpg P_20180303_160124.jpg P_20180303_170616.jpg P_20180303_170838.jpg P_20180303_160138.jpg P_20180301_161710.jpg P_20180303_170341.jpg P_20180303_170345.jpg P_20180303_170212.jpg P_20180303_160153.jpg P_20180228_175656.jpg
    3. INTERMEDIATE/LOWER STEERING ELBOW SHAFTS. I removed both the intermediate and lower shafts via 2 hexnuts screws each, and immediately felt the loose play from the intermediate. Where poss i lubricated joints with white lithium grease.
    - intermediate steering shaft pics
    P_20180301_162319.jpg P_20180301_162321.jpg P_20180303_160209.jpg P_20180303_160212.jpg P_20180303_160232.jpg P_20180303_160234.jpg P_20180303_160238.jpg P_20180303_165702.jpg
    - lower steering elbow
    P_20180228_175558.jpg P_20180228_175600.jpg P_20180228_175621.jpg P_20180228_175624.jpg P_20180228_175629.jpg P_20180228_175635.jpg P_20180228_175640.jpg P_20180228_175642.jpg P_20180228_175646.jpg P_20180303_160153.jpg P_20180303_165936.jpg
    4. SWAP OUT. Replace the old with the new. Replaced the 2 hexnut screws.
    5. BUTTON UP IN REVERSE.
    6. Whoala.
    7. *** COMPARISON. Big difference between the old and newer-replacement. The $7 junkyard replacement piece was damaged in an old Prius. As you can see its was ~2 inches shorter; I had to punch it out with a steel rod against the street, aided by white lithium grease. In fact the whole driver side door collapsed into the driver seat that was pushed down and shoved into the passenger area. I hope the car was empty when hit, because I can only imagine the condition of the driver after an impact like that. But the accident gave me great immediate access to the underside of the dash.
    P_20180303_155811.jpg P_20180303_155820.jpg P_20180303_155826.jpg P_20180303_155832.jpg
    #1 Prius_Angie, Mar 28, 2018
    Sezy and davecook89t like this.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Be aware there was also a tsb issued with free repair on the secondary shaft right below the steering joint. It fixes possible steering failure. Not current though.
    Prius_Angie likes this.
  3. Prius_Angie
    245
    229
    Saint Louis
    ty ETF5
  4. Erik Owens
    Erik Owens Member
    162
    60
    Safety Recall COT.
  5. Prius_Angie
    245
    229
    Saint Louis
    Erik,
    I have never pursued a safety recall before. Since i already addressed it on my own & i discarded the piece, i can only imagine the issue is moot.
    #5 Prius_Angie, Mar 28, 2018
    Sezy likes this.
  6. Sezy
    Sezy Active Member
    443
    233
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Thinking of doing that same thing as my steering is loose feeling and NOT part of the recall after checking Toyota's recall site and a few others. What would you call that part or happen to have a part number?
  7. Prius_Angie
    245
    229
    Saint Louis
    Sezy,
    No fear on the project. Its pretty straight forward from the tear down to problem identification.
    First you need to identify the problem. The loose play may sound similar, but your issue may not be the similar to mine.
    That steering column has 3 elbow joints that may reflect that LOOSE PLAY you are feeling.
    1- So first you need to open up the steering column and check the joints.
    2- clearly identify the loose joint ( it may be 1 or all 3 joints)
    3- order/get the parts online/junkyard
    hope this helps
    Sezy likes this.
  8. Sezy
    Sezy Active Member
    443
    233
    37
    2020 Prius Prime
    Prius_Angie that helps and got me thinking. So I made a video and can reproduce a clunk sound that seems to be coming from higher up that the part you replaced. I'll have to pull all the plastic trims off and see what I can see from behind the airbag down.
  9. Prius_Angie
    245
    229
    Saint Louis
    Sezy,
    OK saw your vid. Without opening up you dashboard, it sounds & looks like your intermediate shaft is defective. There is a noticeable lag before the shaft catches. The upper shaft is real close to the steering wheel.
    Also you shouldnt need to tamper with the steering wheel/air bag. But do uncouple the neg cable to 12V battery.
    Gl
    Sezy likes this.
  10. Sezy
    Sezy Active Member
    443
    233
    37
    2020 Prius Prime
    Thank you Prius_Angie !
    Purchased this intermediate shaft that was listed on ebay as "Brand New" for $25 but came in opened Toyota bag, has sharpie marks & a small metal nick. Seller hasn't replied & the story of the part. Look good to you guys?
    That hair or whatever came with the part, not mine.
    While messing with this issue I disconnected the shaft under the dash and still have a clunk in the steering wheel. Got a steering column & steering wheel coming from a 2008 (mine is 2006). If I'm going to pull more things apart I'd prefer to have all the possible parts I'd need on hand. Can always put them back on ebay if it does not fix my issue.
  11. Sezy
    Sezy Active Member
    443
    233
    37
    2020 Prius Prime
    Well swapped the intermediate shaft and it's only slightly better.
  12. JC91006
    16,939
    8,647
    You should have bought a new one from the dealer. This seller probably installed a new one in their car, saved the old part and the new packaging and sold it to you
  13. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Its common on Toyota vehicles I think. I have done similar tasks on Camry 2004, and Lexus 2001. Kinda manufacturer problem I guess?
