For Sale 2005 (Gen 2) Cardone Right CV Axle $50
Discussion in 'Private Sales' started by Desert Flier, Mar 22, 2022.
  1. Desert Flier
    Desert Flier Member
    68
    Phoenix
    I have a slightly used right CV Axle made by Cardone. It is in excellent condition with less than 5,000 miles on it. It was was replaced while trying to locate a suspension noise that ended up being an engine mount.
  2. JC91006
    16,939
    8,647
    So after 5000 miles, you removed this and put back the old part that you didn't throw out?
  3. Desert Flier
    Desert Flier Member
    68
    Phoenix
    Close. I had replaced all of the suspension and rubber components on the front end but noticed a clack when accelerating. I thought I had it narrowed down to the right front axle. I put about 5,000 miles on the car while troubleshooting. So I pulled this Cardone unit back off and put on a NAPA unit. The noise was still there. I could have returned the NAPA unit but I just didn't feel like messing with it. So the Cardone with less than 5K on it is in the NAPA box in my garage. I bought the Cardone through Rock Auto originally. I ended up using portable magnetic microphones and attached them in various places and finally discovered that the issue was an engine mount all along. Hope that explains it better .
    SFO likes this.
  4. JC91006
    16,939
    8,647
    Not sure if you've attempted to replace the engine mount yet, but it's a PITA
    SFO likes this.
  5. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Which engine mount were either of you talking about?
  6. Desert Flier
    Desert Flier Member
    68
    Phoenix
    The one under the inverter was a pain. Also change the dog bone at the same time.
    SFO likes this.
  7. Desert Flier
    Desert Flier Member
    68
    Phoenix
    The one under the inverter is a real PIA. I also change the dog bone at the same time. That one is significantly easier and is located on the bottom.
