2005 Gen 2 - Left Taillight isn’t lighting after plastic shielding broke - Dealer or home fix?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Seth4, May 21, 2018.
  1. Seth4
    Seth4 Junior Member
    28
    United States
    So I accidentally backed into something and it cracked the plastic shield for the read left taillight. Since then, potentially due to water damage or just an old system, the LEDs and lights on the whole left taillight aren’t working. Should I go to my dealership or does anyone recommend/have experience buying this assembly and doing it themself?
  2. JC91006
    16,872
    8,619
    Buy another one and do it yourself. It'll be half the cost of the dealer's diagnostics
    Raytheeagle likes this.
  3. PAUL SCHULTZ
    PAUL SCHULTZ Member
    103
    66
    Michigan
  4. Stimp
    Stimp Member
    53
    North Carolina
    If there's a chance u want to keep it, I would check the connection first. Also, make sure it's getting power from the car, a replacement won't work without that either. May be blowing fuses if water got in there.
    MickyMatter likes this.
  5. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    I've cracked mine, left side of a 2008, too.
    I bought an used original part from a Toyota dealer.
    The assy comes without bulbs and without sockets (only with the brake LEDs).
    It's easy to change from inside the trunk.
    But I would recommend too, to check the electrics. While the right lights are on, the sockets of the left ones should have round about 12V (up to 13,4V to 13,8V in ready state). If not and if all fuses are okay, a new light assy wouldn't help you further.
    Patrick Wong likes this.
  6. Patrick Wong
    18,210
    6,514
    I replaced the right taillight assembly of my 2007 a year ago. I agree that since the light sockets for the tail, turn and backup lights are not included, replacing the taillight assembly will help the physical damage issue but does nothing with respect to whether those lights actually work.
    If all lights are not working, then it is possible that the connection to ground has a fault.
