2005 hybrid battery, runied by dealer?
Discussion in 'Gen 2 Prius Main Forum' started by fish3d, Dec 13, 2016.
  1. fish3d
    fish3d Junior Member
    26
    I have made a note on my calendar to update in 6 months. Or earlier if I have problems. Thanks everyone for your advice.
    51,966
    congrats, all the best!(y)
  3. fish3d
    26
    I want to thank the community again and a special thanks to ericbecky, who spent a lot of time on phone with me as I plan to see if I can get the additional information from dealer as suggested by him. I just got off the phone with Toyota. I was trying to ascertain whether they would give me a deal purchasing a battery from them. The answer is only if installed by dealer who they said they would call and negotiate a whole page for me. They looked at the following information.
    1. How often car was serviced by Toyota
    2. How many Toyotas I owned ( and or possibly have owned)
    3.She was able to and looked at the invoice the dealer gave me for the 4400.00 estimate, plus the other work that was done that day.
    4. We discussed my interaction with the dealer and she took copious notes. I asked and she said she was writing everything down. For example the fact that the dealer said it was fine to drive car with engine only and other conversations I had with dealer
    5. I told her that the dealer should have provided additional information ( thank you ericbecky)
    likethe "freeze frame" from the diagnostics which might have told me which blocks were bad in hybrid assuming that really was the problem.
    6. If dealer installed new battery it only came with a ONE YEAR WARRANTY...she said this may change.
    Hope this helps
    #23 fish3d, Dec 15, 2016
  4. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    even though your problem seems to be resolved. anyone that owns a Prius should have a mini vci or bluetooth code reader so you can quickly pull codes in case of problems.
  5. fish3d
    26
    I will look into it. Thanks
  6. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    I agree, besides being able to pull out codes, the bluetooth code reader can be used to clear fault codes when you don't have access to basic tools in the car to disconnect the negative terminal for a reset. In the US, you can always get a tow truck in record time for assistance however in some parts of world where fast support is not readily available, you don't want to be on the side of the road with a Prius and no help.
  7. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    Does anyone know if you put the car into Maint mode ,which would be the same process as turning off traction control, can you run the car indefinitely with just the engine running if the car goes into limp mode due to bad HV battery?
    Looking at ways to get from point A to B if the battery fails and car goes into limp mode.
  8. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    I doubt that you would be able to shift out of park once maintenance mode is engaged but I never tried it.
    Are you willing to be a pioneer and find out?
