2005 mesage
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kinglew, Aug 4, 2019.
  1. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    There is a code (see the red triangle next to the speedometer), you just need the right code reader to see it;).
    How’s the 12 volt battery voltage?
    Any recent damage or accidents?
    Recent repair work or maintenance performed?
    Good luck and keep us posted (y).
    52,790
    oh boy, you hit the prius lottery :unsure:
  4. JC91006
    16,934
    8,644
    Check your 12v battery first
    Patrick Wong and Raytheeagle like this.
  5. Patrick Wong
    18,210
    6,517
    The presence of the master warning red triangle does not guarantee that a DTC has been logged. For example if you open the driver's door while the car is READY and in D, that red triangle will come on, yet no DTC will be logged.
    However I agree that the 12V battery is the first item to check in this instance.
    Raytheeagle likes this.
