2005 Prius - 12v Battery Issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MOEsMom, Jul 12, 2023.
  1. MOEsMom
    MOEsMom New Member
    Wisconsin
    Hi!
    I have a 2005 Prius that just hit 100k. I inherited the car when my elderly uncle passed and we’ve really liked it as my husbands commuter vehicle.
    We got the car in October of 2021. We did have to put a new battery in it. It worked perfectly until approx May of this year. In the last few months, the 12v battery has been dying.
    If I put it on the battery charger, it recharges and then works for about a week. Then it dies again.
    I took the battery in, it tested bad, so they gave me a brand new battery (NAPA brand).
    Its been about 2 weeks and sure enough, my husband went to head to work and it was dead again.
    I put the charger on for a while and it started up.
    What do I begin to check? Is this a sign that the main battery needs replacement? I’m just at a loss.
  2. MOEsMom
    MOEsMom New Member
    Wisconsin
    After charging for a bit this afternoon, it started right up.
    But now my Maint Needed light is on. I went to Advanced Auto and had them check the codes. Since it was so late in the day, that was my only option.
    Of course there are three codes.
    P1116 - Coolant Temperature Sensor (CTS) Circuit Stack For Coolant Heat Storage System (it’s listed as pending)
    C1241 - Low Battery Positive Voltage or Abnormal / High Battery Positive Voltage (it’s listed as current)
    C1300 - Malfunction in Engine Control Unit (it’s listed as current)
    Now, none of this means anything to me so I’m going to spend some time deep diving on the internet tonight, but knowing all this … I’m torn if I take it to a mechanic or just get rid of it?
    I am assuming the repair costs for these codes could get quite high and it is just our extra car.
    Any insight, thoughts, advice would be much appreciated since I’m so clueless on this stuff.
    52,863
    two things:
    how often are you driving the car and what distances?
    there is a draw on the battery when the car is off. if it is abnormally high, it can drain the battery prematurely
    MOEsMom likes this.
  4. JC91006
    16,936
    8,647
    I suggest you test the new battery and see if it’s any good.
    MOEsMom likes this.
  5. MOEsMom
    MOEsMom New Member
    Wisconsin
    3-5 days a week - ranging from 20 miles a day to 100.
  6. MOEsMom
    MOEsMom New Member
    Wisconsin
    Well it was a brand new battery two weeks ago.
    Could it still be an issue?
  7. MOEsMom
    MOEsMom New Member
    Wisconsin
    It was a brand new battery two weeks ago … think it could still be a problem?
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    And test the charging voltage with the car in the READY mode too.
    Brian1954 likes this.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    A couple things.
    The MAINT REQ indicator light on a Gen 2 has ONLY 2 meanings and they are both related to oil changes. If you start the car and it blinks for several seconds and then stays off, it means you've reached 4500 miles since the last time it was reset. If it blinks for several seconds and then stays solid, it means you've hit 5000 miles. The recommended oil change interval for your Gen 2 is 5000 miles. When the oil is changed, the "timer" is reset manually using buttons on the dash. The proper button sequence is in the owners manual or can be found online.
    I would not invest ANY money into those codes until you resolve the 12v battery situation, because it's likely they'll go away. Start with ensuring the 12v battery is fully charged. It's recommended to not charge this AGM style battery at more than a 4 amp rate. It will take ~11-12 hours to fully charge at this rate since they are typically ~46AH . Higher rates risk damaging the battery. I've tried it and the warning was accurate. The Prius is VERY poor at self-charging a weak/discharged battery, so "I put the charger on for a while and it started up" may be ok for that single time, but even after a 15 minute drive, it will likely still be too dead to start the car again if you shut it off. You would need to drive for hours to get it at enough charge to reliably start the car again. Keep in mind, every one always says the 12v battery is only needed to power up the computers, etc. Unfortunately, most people also forget that the 12v battery is usually going to initially get hammered by the brake actuator motor prior to being put into READY, and that is a significant electrical load, which will immediately kill a weak battery, preventing it from having a high enough voltage to close the main relays for READY.
    After turning the car off (and make sure you actually turn it completely off, because I have seen cars left on (but not in READY mode) overnight, draining the 12v battery). This is most often done by new owners. The car does not have an alternator and uses an auxiliary circuit inside the inverter to charge the 12v battery. This aux circuit in the inverter keeps the 12v system in your car at about 14v, just like an old style alternator, but only when in READY mode. When not in READY mode, only the 12v battery is used, and it's a relatively small battery so it doesn't take long to drain it.
    MOEsMom likes this.
  10. MOEsMom
    MOEsMom New Member
    Wisconsin
    But to be left on … it would have to have the key in it right??
    I am off to buy a battery tester because I’m more confused than ever. We had a short trip planned and went out of town from Thursday til today. Prius started right up at noon on Monday after not having run since Wednesday evening.
  11. bisco
    52,863
    that is confusing.
    idk if you have to leave the fob in the slot to keep it in, you might have to push the power button to power down whether the fob is in the slot or not.
  12. MOEsMom
    MOEsMom New Member
    Wisconsin
    Ok so tonight I tested the battery …
    This is with the car off … so I think it is good?
    Looking into how to put it on Ready Mode so I can test then.
  13. MOEsMom
    MOEsMom New Member
    Wisconsin
    So I was overthinking the ready mode … this is what the battery says when the vehicle is in ready mode.
  14. bisco
    52,863
    that means it is charging correctly. the voltage with the car off looks okay, but should be higher for a new battery. my 4 year old battery measures 12.78v in the morning after the car has been off about 16 hours
  15. MOEsMom
    MOEsMom New Member
    Wisconsin
    And of course, the codes are still there. I’m just at a loss for what to do next.
    Clearly I’m not a car person and finding someone to look at it who gets this stuff is like finding a needle in a haystack.
  16. MOEsMom
    MOEsMom New Member
    Wisconsin
    ok, it could be something I did when testing. I’ve never used a battery tester before and the one I bought, I had to select the CCA and I chose 500. I think the battery read 475 on the case but again this is a new world to me.
  17. bisco
    52,863
    MOEsMom likes this.
  18. bisco
    52,863
    i don't think the cca would affect the voltage, but i've never had a meter like that. charge it up overnight and read it again after 4 hours or more.
    not many scanners work well with prius, idk if those codes mean anything or not. you might need a coolant control valve, but it wouldn't affect the battery
  19. sam spade 2
    7,035
    2,804
    2017 Prius c
    Two notes:
    That second reading while "ready" is the inverter charging voltage......which is good.....but
    it has nothing to do with the battery itself.
    That first reading of 12.53 with no load is borderline.
    IF it is an AGM battery, the no-load reading should be at least 12.7 or 12.8.
    This probably indicates that it wasn't fully charged when new.......and/or that
    you don't drive much.
    I suggest that it needs to be fully charged, allowed to rest for a few hours
    and then tested again.
    Where did you get the new battery ??
  20. bisco
    52,863
    napa, post #1
