2005 Prius abs light on
Discussion in 'Gen 2 Prius Main Forum' started by Ernie stires, Oct 8, 2022.
  1. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    I’ve read threads on this. Brakes worked fine, was in reverse and had to brake hard, now the abs light is on. Brakes work seems like I am in fail safe mode. I understand that this means the system is basically manual, but safe to drive? I’m traveling and pretty far from home.
    52,667
    i would drive carefully to the closest dealer and get the trouble codes
    Ernie stires likes this.
  3. ChapmanF
    18,863
    If you can find a short piece of wire nearby, you can skip the "drive carefully to the closest dealer" part and just get the trouble codes, by putting the wire between the Tc and CG terminals of the car's diagnostic port, turning the car on, and counting the blinks of the dash lights. A quick search here can find you many threads with the rest of the details on that.
