2005 Prius acting up
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Pasha00, Jun 21, 2016.
  1. Pasha00
    Pasha00 Junior Member
    Land of 10,000 Priuses
    I have a 2005 prius with 38,160 miles
    I started it and shut it off and then tried restarting and now does not want to start. The ready light does not go on and the start button becomes orange.
    I ckecked my 12 volt and it gave a reading of 12.2 volts.
    These are the engine codes that come up:
    U0111 comes up twice
    C0200
    C1259
    C1310
    Any ideas what this problem could be?
    JimboPalmer likes this.
  2. JC91006
    16,933
    8,643
    How about a little history on the car with so few miles? How long have you had it?
    52,781
    sounds like your 12 volt.
  4. mikefocke
    4,073
    1,858
    Sanford, NC
    priuschat is organized into sections related to different models and thus years of production. You may get more insights from finding the section that fits your car as the section for the v is a 2012-2016 era wagon forum.
  5. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    If the 12.2V was with power on, then it's good. If that was with the car off, it's very bad.
  6. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    I don't think it is good anytime...
    12.2 with the car off is bad because the battery is dead.
    12.2 with the car READY is bad because the inverter isn't charging it up to 13.8-14.2
  7. Pasha00
    So is it a issue with the 12 volt or inverter ?
  8. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    If you checked with the car in READY, then inverter or battery. If you checked with car not in READY (most normal), then it is the 12v battery.
    Your symptoms sound like a bad 12v, your readings indicate a bad 12v, so if it quacks like a duck...
