2005 Prius - after ECU replacement, car won't turn off... electrical problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rebecca V, Mar 8, 2025.
  1. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Could you make a video of how the process of starting your car is going? Descriptions are sometimes subjective and do not contain some important points.
  2. Rebecca V
    Rebecca V New Member
    Seattle, WA
  3. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Thanks for the video.
    The question arises - when replacing the ECM, did you program the key fobs to the new ECM?
  4. Rebecca V
    Seattle, WA
    I did not program the key fob to the new ECM, but I have since been able to put the car in drive twice.
  5. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Have you tried connecting the ECM that was removed?
    What are the part numbers (10 digits) on the new ECM and the old ECM?
  6. Rebecca V
    Seattle, WA
    I have not put the old ECM back in yet - does that seem like the most logical next step to you?
  7. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    I see a problem with the immobilizer.
    When I tried to enter the car with a discharged battery and a battery in the key fob, the color music started on the dashboard + the siren from theft was turned on.
    Options - your key is lost, the battery of the key fob is discharged, the 12V battery is dead. It may also be that the new ECU is damaged.
  8. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Check the operation of the key fob without a radio channel. Insert the key fob into the socket to turn it on.
    If you have two keys, check them both by inserting them into the slot in the same way.
  9. Brian1954
    Brian1954 Senior Member
    2,669
    1,068
    South Central PA, USA
    Try the following to try to turn the car off with the 12v battery connected:
    1. Do not step on the brake.
    2. Push and hold the power button for about 10 seconds.
    3. If that did not work, again push and hold the power button about 10 seconds.
    Any luck?
  10. Rebecca V
    Seattle, WA
    Hi all - since your replies I have not been able to recreate the issue to test out these suggestions. Each time the car has turned on and off normally with the key in my pocket. So it works but doesn't seem reliable enough to actually drive anywhere.
    Brian1954 likes this.
  11. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Floating defects are usually defects of contact groups, which are covered with corrosion due to humidity and aggressive chemical environment. There are breaks in wires, the cores of which can connect and disconnect due to temperature changes or shaking of the car.
    Rebecca V likes this.
  12. Rebecca V
    Seattle, WA
    Hi everyone - I wanted to update this thread to mainly say that since I replaced my combination meter, I have had no issues with my car! So anyone having the same symptoms as me, good chance it is your combination meter even though Texas Hybrids didn't think so. I wanted to wait until the weather got cold again to be sure, so that is why I have waited so long to update.
    The main source of the diagnosis confusion (besides my dash lights not going dark) seems to be that I was getting some codes from the ODB scanner that were for something else, namely my ABS ECU. I actually reset those codes and they haven't come back. Nice.
    When I decided to go for the combination meter replacement, Texas Hybrids had increased their costs significantly, so I ended up ordering from Module Repair Pro in CA. There I specified that I have a 2005 Prius, and I ordered a cluster exchange that claimed it would fix the bug where the odo won't count above 299,999: 04-05 TOYOTA INSTRUMENT CLUSTER DISPLAY EXCHANGE - Module Repair Pro INC I now don't believe that Module Repair Pro can actually fix that bug in a 2005 Prius (They have not updated their website since I pointed that out, so maybe I'm the dummy here, but be warned)
    Only after a full dashboard disassembly, replacing the combination meter, and then putting it back together again did I realize that they had sent me a 2006 Prius combination meter (should fix the 300k problem) but without the "required parts to make it work properly in your 2004 or 2005 model vehicle" that is advertised by Texas Hybrid Batteries: Rebuilt Combination Meter 2004-2005 Prius w/ 300K Mile Upgrade | texas-hybrid-battery
    The consequences are that even though the fuel gauge, odometer, PNDR gear display, and left turn indicator lights all worked as expected, seemingly every other dash light was mapped incorrectly. For example, when I turned on my headlights, instead of the headlight symbol lighting up on the dash, the symbol for the rear defrosters came on. When I turned on the right turn indicator light, the headlight symbol flashed, etc. A simultaneously hilarious and discouraging problem. Texas Hybrid Batteries must know how to make an adapter. They are also the only place I've seen that advertises being able to program your desired odo reading into the new combination meter. A shop I visited in person said they would only repair rather than exchange so that the odo reading wouldn't change, and Module Repair Pro will just send you the one with the closest mileage to yours (but for me, that was still 6k off). After the shenanigans -- and at first Module Repair Pro did not believe that they had sent me a 2006 combination meter, I had to call them on the phone and send pictures -- they repaired my original module that I had sent them, I returned the 2006 module, and after the third (and final) dash disassembly and reassembly I put in my fixed combination meter with my car's real mileage and I have had no trouble since. Yay!
    Thanks everyone for giving me the confidence to fix this myself!
