2005 Prius, Battery Replaced in 2009, Good deal?
Discussion in 'Gen 2 Prius Main Forum' started by Caboose, Dec 2, 2014.
  1. Caboose
    Caboose Junior Member
    Portland, OR
    Hello all. Long time lurker, First time poster.
    I am looking at this used Prius which according to the CarFax report, had it's battery replaced in 2009. It has 145k miles, which I've heard is not outrageous for a used Prius.
    Is this a good deal? Anything else that I should know to check for? Is the replaced battery still under a warranty? A family friend works in the sales department at this dealership, so I should be taken care of pretty well, but this is my first car purchase and I want to make sure I don't overlook anything.
    EDIT: Sorry about not being able to Provide URL links; Forum rules will not allow me to post URLs in my first post. The links to the vehicle in question and CarFax report can be found at this post on the /r/Prius subreddit: /r/prius/comments/2o2i82/2005_used_prius_battery_replaced_in_2009_good_deal/
  2. JC91006
    16,670
    8,516
    the replaced battery is most likely the 12v battery, which can be purchased for about $200 and fails every 4 years or so.
    kenoarto and Caboose like this.
  3. Caboose
    Portland, OR
    Oh that's a good point! Definitely something I will ask about during the Sales process as far as clarification goes.
    That being said, at 145k miles, how much of a concern should the battery status be? Anything else that needs extra attention during the buying process?
  4. JC91006
    16,670
    8,516
    The large expensive HV battery is suppose to go for the life of the car (which is about 180k miles) or about 10 years. Since your car is a 2009 with 145k miles, chances are you will probably exceed the 180k miles before it would need replacement
  5. Caboose
    Portland, OR
    The car is actually a 2005. The CarFax report stated the Battery was replaced in 2009. But now that you mention that it's potentially the 12v instead of the HV battery, I'm a little more skeptical.
  6. JC91006
    16,670
    8,516
    Oh my mistake. A 2005 model would soon need a hv traction battery. If you are in a CARB state, the warranty on that battery is good for 10 years or 150k miles. Which you are almost there!
    A new battery will cost you around $2500 if you DIY with a new battery from Toyota. The labor charge for Toyota to put this in, would be anywhere from $300-$1000.
  7. Caboose
    Portland, OR
    I believe Oregon falls within the CARB states, but I was under the impression that the warranty lasted only up to 100k, not 150k....
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Just for the other side of the coin here, there is no magic number when a traction battery dies. Nobody can say that a 2005 will "soon need a HV traction battery". That's just hogwash.
    Many have gone 200K, 300K, 400K and more on the original battery. Some have had it die at 80K or something below the warranty.
    If it lived in a mountainous area or in a place where ambient temperatures are routinely high, it is more of a gamble. Heat and cycles kill batteries. If you live in a cooler flat-land place the battery will usually last a very very very long time. However then you have to be careful of salt on the roads and things like that.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    There are 2 warranties for the hybrid system. Non-CARB states are 8 years, 100K miles. CARB states are 10 years, 150K miles. The powertrain 36K warranty and stuff is all long since gone. It is just the emissions system, of which the hybrid battery is part of, that is still covered.
  10. bisco
    51,076
    how much are they asking? has it had regular maintenance according to toyota recommendations nd all recalls done? how are the tyres?
  11. Caboose
    Portland, OR
    $8995. The CarFax has listed it's service records. (Per forum rules, I can't post URLs yet or else I would link directly to it. Please see top post for links to r/prius subreddit post with links) I haven't been able to look at the vehicle in person yet. Going to see it this weekend.
  12. bisco
    51,076
    that seems fairly expensive, is that the best deal you have found? what package is it, and whats the kbb?
  13. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Caboose, read through Car Buying Guide for New and Used Vehicles | CarBuyingTips.com and be aware that a sale is a sale. The family friend will likely do unto you as done unto everyone else that has walked through the door.
    Register the VIN at Toyota Owners Official Web Site: Service Coupons, Owner's Manuals, Service Scheduling And More to see the vehicle's service history. Trust, but verify.
    The Prius is well built but it isn't indestructible. It's low maintenance but not no maintenance. Are the brakes original? Was coolant changed? Is the inverter coolant pump working? Look for turbulence in the inverter coolant tank.
    During the test drive keep an eye on the state of charge. On the MFD if the bars in the battery fluctuate between fully charged and discharged quickly then you are most likely looking at a traction battery failure.
    Personally, I wouldn't worry about the Prius' traction battery. A GM car would have had a window motor replaced and a blown engine.
    Caboose likes this.
  14. Caboose
    Portland, OR
    Amazing Resource! Lots of service records in here. I was indeed able to verify that it was the 12v Battery that was replaced. Not the HV Battery. I will pour through these documents. Thank you for the suggestion!!
  15. bisco
    51,076
    keep in mind, with gas prices down, so are hybrid sales/peices. kbb shows pkg 3 in my area for $6,500.
  16. Caboose
    Portland, OR
    Yeah, KBB has $6907 for my area (leave it to Oregon Hippies to drive up Hybrid prices). I will negotiate lower.
  17. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It is a shame how near sighted most people are. Good for buyers now I guess. I don't even feel sorry for the idiots buying large SUVs that are going to get another wakeup call in a year.
  18. Caboose
    Portland, OR
    According to those awesome service records you helped me access, looks like the coolant and valve assembly was replaced in April of last year.
  19. Yakoma
    Yakoma Active Member
    470
    125
    sss
  20. Caboose
    Portland, OR
    I've done just that. Lots of service records. Seemed to be consistently taken in every 5000 miles for service and has had it's recall services completed as well.
