2005 Prius, Battery Replaced in 2009, Good deal?
Discussion in 'Gen 2 Prius Main Forum' started by Caboose, Dec 2, 2014.
  1. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Duh...didn't see JimN's post.
    See if you can take it to an independent shop for a pre-purchase inspection. Might cost you $50-75 but it will give you peace of mind if nothing else. Ask to inspect it with the tech. I bought a salvage title Prius from an independent seller, but took it to an independent shop and also to a Toyota service center to get their inspections before making the purchase. The independent mechanic said he'd buy it, but put aside some money each month for stuff that will eventually fail. Remember, it's not a new car and possibly unwarranty-able, but you can get it fixed when it breaks -- even traction batteries. Just be comfortable with the purchase price.
  2. Caboose
    Caboose Junior Member
    Portland, OR
    I did some further scouting into the inventory selection for this dealership, and I found a 2010 Honda Insight also available for around the same price point ($9995, 104k miles). So far, my initial research has shown that while the CarFax reports that the vehicle has only had one owner and is clean, and the vehicle has significantly less miles than the Prius (145k miles) I am interested in, but no service records are available within CarFax or Honda Owners Portal. Whereas the 2005 Prius has lots of documentation showing that the vehicle has been well maintained throughout it's multiple owners.
    The Prius' price was also significantly marked down since I initially looked it up. It's now being listed at $6995 instead of the original listed price of $8995.
    I will have to Test drive them both, if they are still available by the time I get to the Dealership on Saturday. But I wanted to get some feedback or suggestions on whether the 2010 Insight, or the 2005 Prius was the better deal here.
    Thanks again for all the responses. Regardless of my ultimate decision, the advice given here has been invaluable in making this process easier for me.
  3. JC91006
    16,768
    8,565
    No No No on the Honda Insight. There's a reason that car's no longer made. At $6995 it's not a bad purchase. Pocket the $2000 saved and use it for a new battery when the time comes.
    I would still try to find a lower mileage car, however I doubt that one at $6995 will be around for long.
  4. vskid3
    vskid3 Active Member
    773
    228
    Insight isn't a bad car, it just wasn't quite good enough to compete head-to-head with the Prius. It'll get a little less mileage than the Prius, but I've read that the handling is much better in the Insight.
  5. JC91006
    16,768
    8,565
    Darwinism for cars
  6. Caboose
    Portland, OR
    But the mileage difference is pretty vast between the two vehicles. And though I can easily modify the Prius after purchase, the 2010 Insight comes with an AUX/USB port for audio, which is really the only premium feature I really care about.
    Like I said, I'll be gunning for the Prius, but I'll definitely take the Insight out for a test drive.
  7. bisco
    51,937
    insight is not horrible, some people actually like them. but if you look at the sales numbers, not many. the system has issues like, if you have the a/c on, the engine won't shut off when you come to a stop. they'll probably replace it with their new hybrid system, once it's proven.
  8. ePriusdotcom
    ePriusdotcom Junior Member
    Walpole, Massachusetts
    If you put the vin in to the Toyota owners site, open up service records and match the date of the battery replacement with the service date from Toyota. If you click on the date, a detailed invoice with the replaced part numbers should pop up.
  9. Caboose
    Portland, OR
    I'm going in tomorrow to test drive and potentially purchase the Prius! I'll update this post as I can :)
  10. Caboose
    Portland, OR
    Car was sold before I could even get into the dealership today :( Such is life.
  11. Yakoma
    470
    125
    sss
    DOH! There will be others.
  12. JC91006
    16,768
    8,565
    A good prius for $7000 or less won't stick around. But yes, there will be others.
  13. Yakoma
    470
    125
    sss
    You're in a prime month as a used car buyer. Dealers trying to clear their inventory before end-of-year.
    One more tip...listen to this episode of This American Life - 129 Cars.
  14. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Have you looked at the two silver 2005's in Portland, on cars.com?
    One has 158,000 asking $7500 I think
  15. Caboose
    Portland, OR
    I did a long time ago when I started researching this process. Honestly, it left me more intimidated than empowered! But it's definitely one of the best episodes of that show.
  16. Kutanks
    Kutanks Member
    118
    MA
    Have a dealer check the hybrid battery out for you as part of a pre-purchase inspection. I got rid of my '04 with 140k it was only getting about 41mpg I think due to having a weak traction battery. Only got $6,000 but it needed shocks/ springs thanks to Boston potholes. Mine was fully loaded with JBL, Nav, HIDs
