2005 Prius buzzing noise.
Discussion in 'Gen 2 Prius Technical Discussion' started by cuongly267, Mar 17, 2019.
  1. cuongly267
    cuongly267 Junior Member
    Philadelphia
    Buzz when the door is opened.
    Buzz will stop when door is closed
    Buzz when the brake is applied.
    Buzz will stop when brake is released.
    Buzz and stay on when the car is ON.
    Buzz and will stay on when engine running.
    Buzz and will stay on when driving.
    No Check Engine Light
    Brake Light is ON
    (i) icon Light is ON
    ABS Light is ON
    VSC Light is ON
  2. greasemonkey007
    greasemonkey007 Active Member
    287
    107
    South Central Arkansas
    You'll need the codes read, but sounds like it could be a bad accumulator/pump.
    Raytheeagle and bisco like this.
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    I’ll bet your brakes don’t work or feel right, do they?
