2005 Prius, chirping when accelerating
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rogerSC, Jun 3, 2017.
  1. rogerSC
    rogerSC Member
    170
    Just started hearing a chirping noise...seems to be when I accelerate. Oil level looks okay. Any ideas what could be causing this? Doesn't sound like a loose belt to me, but this is the first mechanical glitch in the 12 years that I've owned this great car.
    Thanks!
  2. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    If you're hearing it only when you accelerate from a stop, it could be brakes or tires causing the sound.
  3. rogerSC
    rogerSC Member
    170
    Not just when accelerating from a stop. Just got a couple of new tires about a month ago. Part of what they did was to rotate the tires. They were fine after that...looked at the tires last night, and they look fine at this point. Could be brakes, except I'm not applying them when the noise is being made.
  4. JC91006
    16,936
    8,647
    Maybe your brake pads are low? Or the caliper glide pins are sticking and needs lubrication.
  5. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Only when engine on then? If you tried putting the car in expection mode or the engines only on not the hybrid system
  6. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  7. rogerSC
    rogerSC Member
    170
    Could be...don't know what the symptoms of those are?
  8. rogerSC
    rogerSC Member
    170
    Yes, only when the car is moving, as far as I can tell. When I'm accelerating...doesn't seem to do it when I'm coasting.
  9. rogerSC
    rogerSC Member
    170
  10. rogerSC
    rogerSC Member
    170
    OMG, just took my car for a quick spin. I'm sorry, I hear the sound when I'm not accelerating, and don't have my foot on the brake...when the car is slowing down unpowered. Not sure how I got that backwards, makes me sound pretty flaky, doesn't it?
    Anyways, I've got it right now, the sound that s loudest when it is slowing down without braking.
  11. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    It will tell you if it a engine problem or rolling (bearing) / brakes / A/C or vent lever motor
  12. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  13. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Next time you drive, see if using "B" mode makes a difference in volume or frequency.
    Does the noise seem to come from engine or chassis, can you tell?
    Has the transaxle fluid ever been checked or changed?
    How many miles on the car?
  14. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    I might have been experiencing the same thing you have. I hadn't heard the sound until a couple years ago when I started accelerating. It's not loud and is barely noticeable, so I haven't worried about it. I mainly happens when I accelerate harder than normal and quickly. It happens when the engine delays in starting up after the electric motors initially propel the car.
