2005 Prius codes p0420 p0171 o2 sensor or cat conv
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Taz0523, Jul 10, 2018.
  1. Taz0523
    Taz0523 New Member
    Norwalk, CA
    I am getting these codes intermittently. Check engine light also intermittent. Some tell me it's the cat others the o2 sensors. Is there a way to test? Mileage is over 300k.
  2. audiodave
    audiodave Active Member
    800
    272
    US
    Cat will definitely fix it but the O2 sensor may fix. You'll need to fix out of state or someone out state to send you the parts and a place to do the work.
  3. JC91006
    16,934
    8,643
    Cat 95%
    Raytheeagle likes this.
  4. Dxta
    Dxta Senior Member
    1,943
    769
    Lagos
    Considering the mileage of the car, you might to replace all those parts.
  5. Priusshane
    Priusshane New Member
    Ca
    Have a good used ca cat off a 07 to fix the p0420
