2005 Prius dash no longer working
Discussion in 'Gen 2 Prius Technical Discussion' started by priusmanneedhelp, Aug 25, 2021.
  1. priusmanneedhelp
    priusmanneedhelp Junior Member
    26
    Arizona
    Hello, in November of 2020, I fixed my dash issue by replacing the failed capacitor. Today it failed again.
    Is it common for the capacitor to fail again?
    I live in Arizona so it gets pretty hot here.
    anyone else have this issue?
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Did you only replace the one capacitor, or multiple?
  3. priusmanneedhelp
    26
    Arizona
    only the one. the 220uf 16v i believe.
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Did you replace it with a quality part?
    Wonder if it could be a cable/connection or solder joint issue now?
    There may be additional caps and a regulator that could be replaced as well, the thread below should offer guidance.
    combination meter repair - DIY | PriusChat
    Here are some different takes on the needed parts that you would order :
    combination meter repair - DIY | Page 4 | PriusChat
    combination meter repair - DIY | Page 5 | PriusChat
    combination meter repair - DIY | Page 9 | PriusChat
    combination meter repair - DIY | Page 12 | PriusChat
    Here is another thread that you should be aware of, starting from page 6 :
    T-SB-0172-09 Combination Meter - Intermittent Display | Page 6 | PriusChat
    Please post any updates or fixes here in your current thread.
  5. priusmanneedhelp
    26
    Arizona
    Thanks for the info.
    I think my issue is greater than the capacitor which is unlucky. The dash no longer turns back on when i reset the 12v so i think it is something else. i'll prob just buy a combination meter from ebay.
  6. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    If you're done with the DIY, then you might be better served by purchasing from Matt @Texas Hybrid Batteries - total cost is 150 with free shipping both ways, includes a lifetime warranty, the 299k fix, and will program your ODO for you as well : Prius Speedometer Replacement
    How much are fleabay meters going for these days?
  7. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
