2005 Prius Diagnostic codes P3190 and P0171
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by OCpri, Feb 22, 2018.
  1. OCpri
    OCpri Junior Member
    Renton, WA
    This is all theory as I try to troubleshoot my Prius problem. I read an interesting article
    and if true it sounds like I drained my 12 volt battery briefly while I was running both front, back electric defrosters and running a plug in defroster to defrost the windows because I never got my cabin blower fan repaired. This could have triggered the Engine control module to go back to default setting for the gas throttle valve which is to barely have the valve open at all.
    This would explain why despite repeated attempts at accelerating I found I couldn't get the electric engine to switch over to gas and could only go about 30mph. The gas engine was running but was not recharging the main traction battery and eventually the car stalled to protect the battery from going below it's point of no return (I wanna say 50% or something like that).
    I had my Prius towed and got a code reader to troubleshoot which gave me the codes P3190 and P0171 which are poor gas engine power and fuel system to lean. It seems plausible considering my 12 volt is 4 years old (refurbished Optima deep cycle) and I didn't get the dreaded P0A80 code signaling a defective traction battery so I'm hoping I didn't drain it too badly despite repeated attempts at trying to start it.
    My Question now is, does anybody know of a way that I can reprogram the ECM so it will allow my gas throttle to work again and thus recharge my main traction battery? I hate to have to bring it in to a mechanic so they can figure out the most expensive way to fix this little problem.
  2. dolj
    dolj Senior Member
    8,567
    4,353
    Wellington, New Zealand
    Your "theory" exhibits a gross ignorance of how modern cars work in general and in particular how the Prius works.
    There is no correlation to the 12 V battery. The 2 codes you pulled tell you all you need to know as to where/what the problem is.
    It is a little insulting to all the good and honest mechanics out there to say that. If you do not know what to do with the codes you pulled, you may have no option. Not all mechanics are charlatans, but all need to put a roof over the heads of their families and food on the table. Why do you begrudge them doing that?
    Find a good quality mechanic and let them fix your car.
    SFO likes this.
  3. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Like your comments. Very straight to the point. Nice one.
  4. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    COMICAL!
    The only people who can reprogram the ECUs are Toytoa dealers, the group you are trying to avoid. Only they have the software to update the ECUs, which does not need to be update.
    Did you run out of gas?
    You might have drained the HV Battery w/ your unknown number of failed starts.
  5. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Curious where you read the mentioned article. (was this the article?)
    If that was the article, have you tried cleaning the throttle body already?
    What kind of code reader are you using, not all of them are compatible with hybrids.
    You might try inspecting/testing the MAF (step 6), before you inspect/test the throttle position sensor (step 11), because if the TPS is 'OK' the factory manual says replace the ECU.
    Raytheeagle likes this.
  6. OCpri
    OCpri Junior Member
    Renton, WA
    Yes. That's the article. The code reader is an Inova 3100. Haven't tried cleaning the throttle body yet. Last night dumped another 3" of snow and it's parked out on the street. Snow will hopefully be gone tomorrow. I just don't think it's a coincidence that I have this throttle problem after putting so much stress on the 12 volt. But I probably should check the MAF and TPS first.
    SFO likes this.
  7. OCpri
    OCpri Junior Member
    Renton, WA
    Verified this morning. Correct.
  8. bisco
    52,409
    how many miles on her?
    SFO likes this.
  9. pashko90
    pashko90 Junior Member
    47
    28
    SoCal
    If you gonna need more info, let me know. And fix your blower finally, this is 15 min job.
    SFO likes this.
  10. OCpri
    OCpri Junior Member
    Renton, WA
    I've got 176,000 miles on her. And thank you for the codes pashko90. Have no idea why these codes popped up and here is why.
    Today I took it in to the dealership to get diagnostics run on it. They call me back around noon and say they can't run any codes because the 12 volt is completely dead. So they want to move forward and replace it and charge me $470 for a battery before they can do anything else. I tell them don't touch anything and I'll get my car. I stop to Autozone on the way and pick up a replacement Optima battery for $185 and get the people at the dealership to roll out the prius in the parking lot (they won't let me work on it behind the fenced area) and I put the battery in the car. I proceed to try starting the care and it starts just fine. I drive it around a bit to get the main battery charged and park it back at the dealership.
    There is a simple way to test your prius 12v by using the self diagnostics on the prius menu. 1) press power button without touching brake pedal 2) hold down on the display button on the monitor while turning your headlights on and off 3 times. 3) let go of the display button and you enter the diagnostic screen where it will show you the 12v charge. When I saw 11.5 that number should have raised my suspicions that the battery was bad.
    I could have kicked myself when I realized my mistake. On the plus side, when they examined the car they noticed a leak with the water pump that is dripping fluid on the radiator belt. But was that worth $118? Probably not. I drove it home and am keeping it in the garage from now on.
