2005 Prius ECM replacement reprogram.
Discussion in 'Gen 2 Prius Technical Discussion' started by Brandon Mason, Jun 19, 2019.
  1. Brandon Mason
    Brandon Mason New Member
    Leavenworth
    I just recently replaced the ECM due to a bad lead causing it not to read my position sensor. Now I'm getting a code that says lost connection with ECM, which I expected. I can not find a reprogram or repairing procedure anywhere... Any help would be awesome!!
  2. landspeed
    landspeed Active Member
    387
    210
    NZ
    2003 Prius
    If it was the lead, is the original ECM still,OK?
    ECUs can be reflashed via tech stream and .cuw files - from Toyota - but immobilisers are another issue and I don’t know how to fix that issue
  3. Brandon Mason
    Leavenworth
    The original ecm was okay, but the sensor wasn’t getting any voltage for the crankshaft position sensor. I tried the reset procedure where you jump the obdII and let the car go on acc mode for 30 minutes with no luck. I’m not sure how to swap the e proms still trying to find information on that.
  4. ChapmanF
    18,955
    I don't think there is any reprogramming/repairing needed for the ECM. I'd hunt for some other problem.
    Between the HV ECU and the immobilizer, there is a pairing relationship, but you didn't swap either of those. IIRC, they re-pair just by leaving the ignition ON for 30 minutes without trying to start. Or maybe that was just for Gen 1.
    landspeed likes this.
  5. landspeed
    387
    210
    NZ
    2003 Prius
    I didn’t know it was just the HV ECU that linked to the immobiliser - that is good to know!
    Can you let us know more about what happened, and what was wrong with the old ECU? Which ECU was it? Did the old one lose communication? If not, could it be a bad replacement ECU? Was the wiring loom damaged in any way?
    If it was the HV ECU then pairing it might be needed - but it seems the engine ECU and others won’t need that.
  6. landspeed
    387
    210
    NZ
    2003 Prius
    Do you still have the original ECM? Also, when you say it wasn't getting voltage from the crankshaft position sensor, could it be somewhere between the sensor, and the wiring, or was that checked out to be OK? (e.g. is the fault something on the original ECM circuitboard?).
    It might be worth putting the original ECM back in and seeing if is still unable to communicate, assuming the ECM isn't doing anything like shorting out the connected sensors. If the original ECM can communicate, then it points to bad luck with the new ECM being faulty in some way?
