2005 prius engine replacement
Discussion in 'Gen 2 Prius Main Forum' started by Rick REEDER, May 22, 2021.
Tags:
  1. Rick REEDER
    Rick REEDER New Member
    Bay Area, Calif.
    Any recommendations on who can do this work in the SF Bay Area, Calif?
    Car has near-new toyota hybrid battery, new computer, catalytic converter theft shield, around 150K miles.
    (either oil pan was punctured or the engine ran out of oil - thrown rod.)
    Had a deal on a used engine to replace blown gas engine on 2005 Prius then mechanic bailed out.
    Plan is to replace bad engine with a good, used Japanese one and then sell to recoup costs. Or, should it be parted out?
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Welcome to PriusChat!!
    There is a Toyota/ASE trained tech in the east bay, send me a private message or "Start a Conversation" (if this feature works for you).
    Have you already sourced/procured the engine, with or without the transmission?
    #2 SFO, May 22, 2021
    Raytheeagle likes this.
