2005 Prius Front Brake Problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sonofabeach89, Apr 2, 2021.
  1. Sonofabeach89
    Sonofabeach89 New Member
    Binghamton NY
    Hello I need help. I have a 2005 toyota Prius. My front brakes wont work, only my back brakes work.
    Heres a little history. I replace front brakes a couple months go and they still have meat on them. My ABS, Brake and (!) Lights are on but they have been on for over 4 months (dont know the code). 2 weeks ago I got both font wheel bearings replace. I notice the front brakes starting to not work yesterday when i went to pick up my son but it seem like they started to work again after driving a little. Then goimg to work and back i had no front brakes so im trying to see if i can figure it out before i spend a arm and a leg sending to the shop as I just spend over 1k on wheel bearing being replace.
  2. Mendel Leisk
    42,287
    Maybe back up and ask yourself: “Am I being responsible?”.
  3. Sonofabeach89
    Binghamton NY
    Well yes i used my blinkers!
  4. Thebakerman
    Thebakerman Member
    149
    60
    It's pretty obvious to me at this point, it's a wheel speed bearing sensor. The only way to know is to buy a 20 dollar scanner and check the code. Without having a check engine code it's hard to tell. However my money is on, wheel sensor bearing which one goes out, the whole abs system goes out. Then it's like driving a regular car except on freeway it will regenerate battery. Fyi
    Sonofabeach89 likes this.
  5. Thebakerman
    Thebakerman Member
    149
    60
    You need to be more specific on what dash lights are in and buy a scanner. This will tell you exactly what's wrong. Right now it's a crap shoot!
