2005 prius gas engine wont start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by motocrosser4, Nov 9, 2015.
  1. Bob Greenough
    Bob Greenough Junior Member
    23
    Laguna Hills, Ca
    Thanks for the feedback.
    I am not sure what you mean "Does the car become ready when I power Up". What are we looking for?
    When i push the power button, the lights come on, but it does not start. I guess is that it is not ready when I power up. Something is keeping it from starting.
    Bob
  2. Patrick Wong
    18,210
    6,517
    No trick, assuming that you have properly installed the traction battery interlock by pivoting the lever 90 degrees, then sliding the lever down to lock it in place.
    The question about the car being ready is asking whether you see the READY light appear in the combination meter display. If you do not, then the car is not ready.
    I suggest that you obtain Mini VCI so that you can retrieve the fault codes logged by your car's ECUs, which will give you a clue about what may be wrong with your car besides a traction battery module.
    Bob Greenough likes this.
  3. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Check if you have power at relay smr1 in battery compartment next to ecu. You should have full voltage on one side of relay smr1 200 + volts DC
  4. motocrosser4
    motocrosser4 New Member
    los angeles cs
  5. motocrosser4
    los angeles cs
    Ok so i just installed both integration relays b and c and car still wont start. The 15 amp efi fuse on the integration relay keeps blowing as soon as i attempt to start the car, which it was blowing before i change the integration relays.
    Any ideas, i put my 12v battery on a slow charge to get that back to normal.
  6. motocrosser4
    los angeles cs
    I just installed bothe integration relays and still nothing. 15 amp efi fuse is still blowing.
    Put a slow charge on 12v battery. Im stuck
  7. Patrick Wong
    18,210
    6,517
    The 15A EFI fuse feeds the engine ECU through the EFI M relay. It feeds the fuel pump through the C/OPN (circuit opening) relay. It also provides power to the mass air flow sensor, the air/fuel ratio sensor heater, and the downstream oxygen sensor heater.
    What makes troubleshooting difficult here is that both relays are part of the integration relays. EFI M is part of the Unit B integration relay while the C/OPN relay is part of the Unit C integration relay.
    I suggest you buy several 15A fuses for use during troubleshooting. Then, pull Unit C integration relay and see if the 15A EFI fuse will blow when that relay assembly is absent.
    If it does not blow, then try disconnecting the fuel pump and then reinstall Unit C integration relay. See if the fuse blows. If the fuse does not blow, then the problem is downstream from wherever you disconnected the fuel pump, perhaps the fuel pump motor is shorted for example. In that case you would have to replace the entire fuel tank.
    If the fuel pump is not the issue, then there may be a problem with the wiring to the MAF sensor, a sensor heater, or one of those parts may be shorted.
    You could try disconnecting all of those parts, and see if the 15A EFI fuse remains good. If it is good, then reconnect the parts one at a time, until the fuse blows. That last part to be connected would be the bad part. If the fuse blows even when all of the parts are disconnected then there is a wiring harness short somewhere.
    Obviously your troubleshooting will be enhanced if you have the electrical wiring diagram for your car, which you can obtain at the subscription website techinfo.toyota.com
    Mrs.Diamond and Bob Greenough like this.
  8. JC91006
    16,932
    8,640
  9. Bob Greenough
    23
    Laguna Hills, Ca
    Thanks for the feedback. This is clear and helpful.
  10. Bob Greenough
    23
    Laguna Hills, Ca
    Thanks for the detailed feedback. I will order an electrical diagram as you suggest and continue the troubleshooting.
    This was very helpful.
  11. Bob Greenough
    23
    Laguna Hills, Ca
    After several attempts, I am at a point where I will need some more specific help or I will need to purchase a replacement battery pack.
    - I have not rebalanced the batteries, but 26 of the cells are between 7.4 and 7.6 and two cells 7.75 and 7.69 (28 total). This is a little out of family, but I do not have a diagram to set up the charging/balancing the voltages closer.
    - I have measured 217 Vdc on the battery side when I have all of it put together in the car.
    - Removing the positive and negative cables on the 12v battery should reset the system.
    - I am still getting error lights when I attempt to start the car.
    I am wonder what sets the fault modes. i.e. How does the start up test software work? Or is there a hard wired voltage value that sets the error indicators.
    Does the Battery computer assembly typically fail?
    Any additional feedback would be appreciated.
  12. Bob Greenough
    23
    Laguna Hills, Ca
    no, It does not become ready when I power up. I am still getting the lights in the dash.
    I am assuming that there is a fault mode that is telling me that the batteries are not balanced.
    After resetting the modes as well as disconnecting the battery to reset the system, I thoughts that the car would start up and then provide any errors then.
  13. Bob Greenough
    23
    Laguna Hills, Ca
    I am taking your advise and replacing the traction battery. I will let you know how that works out. Thanks again for your help. Greatly appreciated.
  14. motocrosser4
    los angeles cs
    Sorry for getting back so late, will follow these steps when im off from work this coming Thursday and will let you know what happens, thank you so much for your knowledge. Where would the sensor heated be located?
  15. Patrick Wong
    18,210
    6,517
    The heaters for the A/F ratio sensor and the O2 sensor are integral parts of each sensor.
  16. motocrosser4
    los angeles cs
    Would you happen to know where i could get a wiring diagram for the efi system?
  17. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If any of you need the Gen2 Prius Technical manual, send me a PM and I will reply with links to zip archives (there are two: 2004-2005 and 2006-2009) on my personal web server.
    JeffD
  18. Patrick Wong
    18,210
    6,517
    The electrical wiring diagram is available at techinfo.toyota.com
  19. motocrosser4
    los angeles cs
    Well guys, after 20 days of troubleshooting i finally decided to jack the car up and what do i find? A missing catalytic converter!!! Yes the scum of the earth people cut it out with a sawsall right on camera at 1:54am. The reason for the efi blowing was because the they cut the o2 sensor wires and they were stuck together. PISSED OFF!!!! I ordered a whole ne exhaust from amazon for 300$ because i didnt feel like a weld job from a muffler shop, the one i ordere is bolt on.
    m.wynn likes this.
  20. JC91006
    16,932
    8,640
    just so you'll know, you might fail a smog inspection in CA from the aftermarket cat. It's not legal.
