2005 Prius has Triple Critical Month
Discussion in 'Gen 2 Prius Main Forum' started by penquin230, May 20, 2014.
  1. penquin230
    penquin230 "Golden Hawk"
    85
    Atlanta, Ga.
    Just in the last month my 2005 Prius has been on a Triple Critical. #1 my LED brake light on drivers side went bad. Cost me $72 for part and about 40 minutes to swap out tail light...#2 my lower hatch glass (small piece under spoiler)cracked like a spider web. I taped over it with 4 inch packing tape to give some time to shop for new window installed.I got quotes from $849, 696, 689, 596 and $423 . Binswanger had the cheapest installed quote so I called to set up appointment.They told me the piece of glass was unavailable from there vendors...so they couldn't honor there quote.Toyota wanted $307 for the glass but they didn't have anyone to install it.I ended up getting glass from AutoBeYours and a glass installer to put in in. Out of pocket $290.#3 just 2 days later the Prius got Triangle of death CEL, ABS and a couple other icons. checked code with code reader P0A80 Hybrid Battery Failure.Cleared code and Prius went ready. during my test drive I noticed Battery dropped down to purple bar when in stop and go traffic but would recover to upper blue bars when I drove at 40 mph about 1 mile. still when idling would go back to purple bars. I'm now waiting for UPS to deliver my Prius Rebuilt battery. It's a gen2 battery with gen 3 cells in it. my final cost will be $1570 after my core refund. I'll post later about the new battery.
  2. RichinMaine
    RichinMaine New Member
    Lewiston, Maine
    how many miles do yo have on it???
  3. JC91006
    16,925
    8,637
    Sorry to hear about all your problems, hopefully this will be the end of it....
    How do you verify the cells are from gen 3?
  4. penquin230
    85
    Atlanta, Ga.
    132K ,,,I bought Prius with 86K about 2 1/2 years ago.
  5. kammssss
    kammssss Member
    287
    86
    SoCal
    What company did you buy the battery from? Is it verifiable that the cells are from gen 3? I got 264k on mine, so I am preparing to buy one myself. Thanks.
  6. penquin230
    85
    Atlanta, Ga.
    Rebuilt Toyota Prius Hybrid Battery for Generation 2 Prius
    Toyota Prius Rebuilt Hybrid Battery for Generation 2 cars rebuilt with Generation 3 cells.
    This battery features newer Generation 3 battery cells rebuilt into the Generation 2 core.
    Generation 3 battery cells are the newest version and have the longest life-expectancy possible when compared to generation 2 battery cells.
    This rebuilt battery is highly recommended for customers who are planning to keep their Generation 2 Prius for 3 years or longer.
    This item is rebuilt with good used cells that all have been serviced and tested using our advanced tech methods to check voltage, load, capacity, and endurance.
    These cells have performance levels much closer to new cells compared to Generation 2 cells.
    All cells have passed acceptable thresholds for performance.
    All connections and bus-bars are refurbished and nickel-plated using our special advanced technique.
    This battery comes with a 12 MONTH warranty.
    I will install battery day after tomorrow (Thursday) I'll post more on Friday.
  7. Patrick Wong
    18,210
    6,517
    Open the new battery case and compare the physical appearance of the modules to the original battery modules. I believe there are slight form factor differences.
    penquin230 likes this.
  8. JC91006
    16,925
    8,637
    I've read from jeffd, the gen3 cells are superior to gen2. You would think Toyota would stop production of gen2 cells in favor of gen 3. Seeing that both gens are compatible
    SM-N900P ?
  9. penquin230
    85
    Atlanta, Ga.
    I've been told that gen3 batteries have a lower resistance, therefore they produce more energy without generating as much heat...plus they are newer batteries from 2010-2013 battery packs versus gen2 batteries that could be from 2004-2009 battery packs...watching my friend Dave strip out the inside of the rear half of the interior, we muscled out the old battery and dragged the new one into place...hooked everything back up and reinstalled rear seat backs and all panels back in place , didn't even have any leftover hardware.I started up the Prius to take for a test drive. went 10 feet and mpg said 1.2mpg,another 150 feet I was at the stop sign 2.3mpg.drove around 20 miles and it was reading 52.3mpg. Drove back home about 15 miles and arrived home with 50.7mpg.. My initial feeling is that transplanting a gen2 pack with gen3 cells was a viable choice for me. I'm planing on taking my bride of 28 years on a roadtrip this weekend,Hope to have a very good break in of "New" battery pack...
  10. kammssss
    kammssss Member
    287
    86
    SoCal
    Thanks...sounds like a good deal.
  11. kammssss
    kammssss Member
    287
    86
    SoCal
    Do you have a Scangauge? I would love to know the state of charge of the HV battery while it is being heavily used (i.e. climbing a hill or heavy AC usage). My state of charge would never go less than 40% (I think it's not suppose to go lower than this) when the car was newer. Now, however, it falls below the 40% when climbing a hill or the AC is being heavily used. I've seen it in the 20% many times. I just have to slow and let it charge itself up. To me, this is a sign that the HV battery is on its way out. Thanks again.
  12. penquin230
    85
    Atlanta, Ga.
    No I don't have scangauge, But yesterday while driving in the Blueridge Mtns my wife was driving and said that the car seems to have more power going up the mountains without pressing the car any harder. I figure that the gen3 cells provide a better power band , Even with driving up and down the mountain roads we got 50mpg in driving 140 miles.And my wife doesn't "play the game" she just drives like a regular "ice" car...
