2005 Prius - Hybrid battery lights again
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ringinear, Jun 20, 2015.
  1. ringinear
    ringinear Junior Member
    Hawaii
    A year and a half ago, I had the hybrid battery warning lights come on and had it towed to the dealer. After given the option of replacing the battery for $4300, I took it home and did a single cell replacement (all cells ~8V, one at 6.6V which I replaced), which seemed to be all good until yesterday. Back with the warning lights and blower fan, I jumped to the conclusion that I have a similar situation, removed the battery and all cells are 8.04V +/- .05V except for 1 cell at 7.92. I am not convinced that this cell is really the culprit.
    I would appreciate any thoughts on what my next step should be here. Thanks very much.
    52,747
    it could be that under load, a cell is further off than when you take a static reading.
  3. JC91006
    16,928
    8,637
    Well if you're going to play whack a mole, you should now change the one that's 7.92 volts
  4. brucebee
    brucebee Junior Member
    84
    vista, ca
    how many miles did you get before issue returned? sounds like you got a good run
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Get a code reader.
    It should point you in the right direction
    Other possibilities:
    Same module is bad
    Different module is bad
    Too much deviation between the modules.
    Loose connection
    Corrosion
    HV leak
    Measuring the voltages under load would be more useful.
  6. ringinear
    Hawaii
    Over a couple of days, the voltage (unloaded) on the one cell did go down and I replaced it with an ebay module. After a month,back with warning lights and
    Fan running constantly.
    The codes are the Port and P0A80. I am guessing that the single module replacement bought me a year or so but now need a recondition or replacement pack.
  7. bisco
    52,747
    i concur. or get a mini vci, and go the rebalancincing route explained in other threads.
  8. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    This is a typical "Whack-A-Mole" game that is played when doing single cell replacement. Especially without periodic pack balancing to mask any imbalances. Even then it can be an ongoing challenge.
    Thanks for reporting back on your continuing saga.
  9. ringinear
    Hawaii
    Thanks for all the feedback. I decided to purchase a charger and see if I can do a recondition. So I ordered a Hitec X4 charger and
    was going to try to start off with the settings I've seen elsewhere and see how it goes.
    These would be a
    (7.2V NiMH)
    Charge : 2A
    Discharge Current : .7A
    Discharge Cutoff V : 6V
    NiMH Sensitivity (delta V) : 7mV
    Waste charge time : 5 mins
    Safety Timer : off
    Capacity cut-off : 7000 mAh
    I'd appreciate any comments or suggestions on these parameters. Also, wondering if I should maybe lower the capacity cutoff since my battery has suffered some pretty warm Hawaii temperatures over the years. Thanks again for any and all advice.
  10. bisco
    52,747
    are you studying the other rebuilding threads, or flying by the seat of your pants?
  11. ringinear
    Hawaii
    Very much studying other posts and the rebuilding threads.
  12. bisco
    52,747
    excellent, all the best.(y)
