2005 Prius. I dropped my keys and my key fob was run over.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hbbird, Oct 15, 2021.
  1. hbbird
    hbbird Junior Member
    16
    I retrieved all the parts I could find and the circuit board was found. I bought a new fob shell and am trying to put it back together to at least give it a chance to work. But, upon looking at two disassembly videos I find that a part that is missing is a little plastic piece that is inserted near the battery. According to one of the videos, the remote function will not work without this little plastic piece. Does anyone know what this piece is called and whether I might be able to find one somewhere. I really don't want to pay $200 for another fob. I have one functioning fob and need a spare. I have about 125K on my little Prius and it runs like a charm.
  2. JC91006
    16,470
    8,383
    That is the RFID chip, used to start the car when it’s held next to the power button. It allows the car to start even if you have a dead battery
  3. dolj
    dolj Senior Member
    7,510
    3,774
    Wellington, New Zealand
    The fob needs to be put in the slot in a Gen 2.
    JC91006 likes this.
  4. JC91006
    16,470
    8,383
    Oh yes, I forgot Gen2 actually has a slot. Been a while since I've actually put a key in the slot.
  5. Another
    Another Senior Member
    1,802
    510
    Naples, Florida
    New keys are easily obtainable these days. Even ACE Hardware sells them and programs them for you. Otherwise a bit cheaper on eBay with the usual risk that they won’t work.
  6. JC91006
    16,470
    8,383
    ACE? How much would they charge for a key fob and programming?
    I checked a couple weeks ago for a key on dealership websites, they seem to not sell them anymore
  7. Another
    1,802
    510
    Naples, Florida
    Just call your local ACE and ask
    Price may vary between geographic locations.
    They have a huge display in mine and keys for all makes and models including Prius.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    3,254
    1,359
    NJ-USA
    Do you have SKS? (little black button on the outside door and tailgate handles- two buttons under the dash- silver logo on the key fob- car unlocks if you just walk up to it with the fob in your pocket). The circuit board on a SKS car is the wireless remote entry and "allow things to run because it's near" part. The (missing) RFID chip is a separate piece that only works (allows the car to start) if the fob is inserted into the dash slot.
    A non SKS car has the RFID chip but the circuit board only works to remotely lock or unlock with a button push.
    First see if the circuit board still works. Hold a battery in place and push a button- does the little LED light up red and the car respond? If not then the board is likely broken. If it's not SKS then AFAIK you can get a used fob and program it to the car (using the "chicken dance? or Techstream). If the board does work then you can buy any gen2 used fob and program that RFID chip to your car and put the chip and your board and mechanical key in a new case.
    If your (SKS) board is broken then you need to get a new or "virginized" fob to be able to program it to the car. (There is a process to get around this for a used SKS fob but that involves Techstream and special codes from questionable websites).
    A place like Ace should be able to cut a mechanical key and "clone" the RFID chip on your good fob, but I have no idea what they would do for the remote entry functions- esp if it was for SKS.
    edit: just googled and amazon shows a new aftermarket fob for gen2 SKS cars for $105. Use your good fob for "chicken dance" programming. Reuse the existing mechanical key or have the new blank cut.
    #8 mr_guy_mann, Oct 16, 2021
