2005 Prius, inner AC vent panel
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by marty6strings, Jan 16, 2014.
  1. marty6strings
    marty6strings Junior Member
    Ben Lomond, CA
    My baby is still rolling along, 140K plus but cosmetically getting a little beat up. I want replace the passenger side inner AC vent panel - any ideas out there where I can score one?
    Thanks,
    Marty
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Try a local junk yard. Should be able to find that on a unit sitting waiting to be crushed.
    You could order one new from Toyota, but it would probably be a little on the expensive side.
    Take a look here.
    2005 Toyota Prius Parts - AutoNation Toyota Gulf Freeway Parts
    If you call the 800 number listed on their site, ask for Jake. He is very knowledgeable and can help you select the correct part. I don't see the inboard vent listed on the page above, but the outboard ones range around $120 on the site. So unless you have a couple of c notes in your pocket to burn, you might want to check the local scrap yards first.
  3. Patrick Wong
    18,210
    6,517
    Try autobeyours.com
