2005 Prius is slowing down faster than it used to
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bill02888, Jun 24, 2023.
Tags:
  1. bill02888
    bill02888 Junior Member
    Massachusetts, USA
    Hi folks,
    The other day I had to make a 3-point turn on a narrow street. Ever since then my Prius feels like it's slowing down more quickly than it used to.
    Had my regular mechanic check my brakes. He says they're fine. Slide pins are sliding freely. No marks to indicate that the pads were grabbing recently. He doesn't feel any bad slowdown. Admittedly it's not horrible, but I've had this car since day 1 and it's noticeable to me.
    Can re-gen suddenly get stronger? It also feels like I'm having to press a bit harder on the accelerator to get it moving.
    Only 260,000 miles! Any thoughts?
    Oh, it's blue! -- Seaside Pearl. ;-)
    Bill in MA USA.
    52,918
    what happens when you put it in neutral around 30mph
    Tombukt2 likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    13,879
    2,521
    Durham NC
    And since day one you're still on your original traction battery and all that or?
  4. bill02888
    Massachusetts, USA
    (1) I'll try switching to neutral around 30 MPG tomorrow to see what happens.
    (2) Yes, still on original traction battery. Biggest expense to-date was a new cat converter a year or so ago.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    18 years and 260K miles......
    And you seem surprised that you are finally seeing some signs
    of age from the engine and / or the HV battery ?
    REALLY ???? :rolleyes:
  6. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Now might be a good time to 'top balance' or recondition the HV battery. What is your MPG historically and currently.
  7. bill02888
    Massachusetts, USA
    BTW, the traction packs look fairly reasonable to me:
  8. bill02888
    Massachusetts, USA
    I'm a conservative driver. 55 MPG in the summer. 50 MPG not in the summer. According to the guess gauge. Car is parked inside my garage when not in use.
  9. bisco
    52,918
    i wonder if the 3 point turn caused a suspension problem
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    Might not be too.
    Probably WAY too late.
  11. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Could be, but a little can go a long way... even on PriusChat. Personally wouldn't gamble on 300k at this stage of the game. But TMMV*.
  12. rm04
    rm04 Member
    53
    27
    United States
    Make sure you're in D gear and not B
    SFO likes this.
