2005 Prius loud clatter from ICE
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by zakkotun, Apr 12, 2020.
  1. zakkotun
    zakkotun Junior Member
    Houston, Texas
    Does anyone know what is going on with my 2005 Toyota Prius? It has 125,000 miles on it, bought use 5 years ago, and I have recently balance the hybrid battery. I have changed the ignition coil, spark plugs, fuel injectors, front & back exhaust gaskets. But this noise never stops:
    https://youtu.be/bw7xvpWgqzM
    #1 zakkotun, Apr 12, 2020
  2. dolj
    dolj Senior Member
    8,625
    4,381
    Wellington, New Zealand
    Upload the video to YouTube and link to it in your post.
  3. zakkotun
    Houston, Texas
    Thanks so much, I spent the whole Sunday trying to Upload, didn't work until you suggest. Thanks again!
  4. dolj
    dolj Senior Member
    8,625
    4,381
    No worries. (y)
  5. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Have you read the fault codes? Any misfire codes?
    Correct oil level in the engine? Does it consume oil? Has it been almost run out of oil?
  6. strawbrad
    953
    1,007
    A guess would be a broken piston skirt.
    How does the car run? Is there a lack of power? Does the noise go away at higher engine speeds?
    You could remove the lower oil pan to look for junks of metal. That would be less money and work than you have already spent trouble shooting the problem.
