2005 Prius MFD Trouble
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BentSpace, Feb 10, 2018.
  1. BentSpace
    BentSpace Member
    195
    Reno
    The Multi Function Display on my 2005 Prius has been acting up for a few months now. Occasionally it will work normally, possibly more when it’s colder, but other times it acts all crazy displaying the normal screen with numbers missing or scrambled or just something bizarre and then it also seemed to be reseting often, as if I’m listening to something on the sound system it will stop when it resets. Sometimes it displays the Lexus logo. I did have it removed the whole dash including the MFD about a year ago when I was changing the odometer display which went out.
    Any ideas what going on here?
    52,855
    try disconnecting the 12v negative for a few minutes. if that doesn't work, you may have to replace it.
    how many miles on her?
    BentSpace likes this.
  3. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    Does that work for the MDF, and he already has replaced the CM?
    @BentSpace, the MDF has been know to develop bad solder joints, the details of which you will need to use the search function. The MDF can be remedied by reflowing the joints.
    52,855
    only one way to find out...
  5. BentSpace
    BentSpace Member
    195
    Reno
    I tried disconnecting the battery for a few minutes. When I started it up the MFD was just black. Haven't driven it around yet though since, so maybe it will come back on. Also noticed my gas gauge was reading empty, even though I just filled up.
    It's got 266,000 miles on it.
  6. Prodigyplace
    12,713
    11,848
    Central Virginia
    The gas gauge reading is normal. It takes a while to figure things out after the battery has been disconnected. I forget if adding gas helps or not.
  7. BentSpace
    BentSpace Member
    195
    Reno
    So my screen finally died completely and doesn’t come on anymore at all. I assume it’s that common problem for cars of this year. Wondering what my best option is now. I looked at hobbits fix for it and was considering trying to do it myself. I have a soldering iron. Sounds a little tricky though. Any of you guys do it successfully?
    There’s a lot of used ones on eBay for around $200, but since it seems like a common problem i was worried that it might break soon after purchase or already be broken.
    Prius MFD Touchscreen Repair Or there is these people that will fix yours, if you mail it to them for $299.
  8. Prodigyplace
    12,713
    11,848
    Central Virginia
    Many people use one of our forum members.
    Prius Speedometer Replacement
  9. BentSpace
    BentSpace Member
    195
    Reno
    Just called Matt and he said he doesn’t do them. Refered me to the guys I mentioned in my post, autobeyours.com.
  10. boppo
    boppo Active Member
    799
    139
    Owego, NY
    I have a display for a 2005 prius, if your= are interested.
  11. BentSpace
    BentSpace Member
    195
    Reno
    Does anyone know if you can replace a MFD with navigation for one without?
