2005 Prius no start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Eby6114, Mar 27, 2016.
  1. Eby6114
    Eby6114 Junior Member
    24
    Wildwood F L
    Hi all, just got the car drove over 1000 miles without issue. Then it rained a few days, could be unrelated. Drove a quarter mile and it all went to ... Finished the 3 miles and it wouldn't start. During said trip red triangle engine and exclamation mark yellow haunted to screen. Turned off the AC to listen. No strange noise. I believe only the ice was running, no hybrid. Regen was working. Current lights red triangle, yellow exclamation, brake, engine, abs, red car with exclaim, anti skid, will go into neutral. Power button will not turn green just amber. Battery 12.4. Hybrid almost full, inverter pump working. No thrown codes under info 3 seconds slash lights on off 3 times. Emv says ok. Brake lights working. Ideas?
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    The ICE and Hybrid system work together. The ICE will not function without the hybrid system.
    Confirm that the 12v is in good condition.
    Next get the code read. That will give you an idea of where the actual problem is.
    #2 ericbecky, Mar 27, 2016
  3. Eby6114
    24
    Wildwood F L
    So inverter pump is working fine. Now charging the 12 volt battery. Car is not throwing codes when info button is pushed and lights on off 3 times. Thanks. Dread to take this to Toyota, would rather go testing various things, about to open hybrid battery and meter the volts, BTW I always do my own work except pressing bearings. Thanks again
  4. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    You are only reading codes from the radio with that trick. It’s really only useful on checking 12V battery voltage. You need to read the codes. If you want to do it yourself get Mini-VCI and Win XP laptop. Or take it to a shop that can read Toyota hybrid fault codes.
  5. bisco
    52,781
    welcome! have the codes read. is the 12.4 with the car off? how old is the 12 volt? how many miles on her?
  6. JC91006
    16,933
    8,643
    sounds like a problem with your hybrid battery failing
  7. Eby6114
    24
    Wildwood F L
    Ok, so 143 k miles, I'll have to order a code reader, unknown on the battery, 12.4 car off, disco the hybrid battery a whopping 220v on the battery, removed bus bar. Individual cells read mostly 7.9 and one or two at 7.8. Note!!! The car acted no differently with the quick disconnect aka the orange rocker removed. Tried re rocking it and nothing changed. I mean from the self diagnosis to the warning lights nothing changed. Man scratches his head... hope that narrowed things down?
  8. JC91006
    16,933
    8,643
    did you lock the orange plug in place? You have to push down on it to lock it.
  9. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Short of confirming your 12 volt battery's condition (btw is a genuine toyota 12 volt battery the date of manufacture is marked on the top of the bsttery. You msy hsve to remove the battery hold down to read it) and confirming your inverter pump is running you are pretty much at a stand still until you retrieve your dtc's. Let us know when you get them pulled.
  10. Eby6114
    24
    Wildwood F L
    12 volt battery's in great shape 12.8 volts put a load on it and it handled nicely, orange disconnect is engaged properly, ordered scan tool. Will clean bus bars on both sides and re install. While I wait for scan tool going to test hybrid relay when start button is depressed using clips and meter, meter has high volt indicator with audio so I can do both at same time. Pretty sure somethings not allowing power thru, perhaps a safety feature for a malfunction like hybrid cooling fan is toast so won't allow relay to engage. I won't bypass relay but if I can find the specs I can pull the feeder plug and see is there's power to engage said relay and if there is and relays not working bobs my uncle or... your uncle. Oh by the way this happened Saturday and my vw golf diesel water pump started pouring water sunday, which is a total timing job but at least it's definitive, thanks again
  11. M in KC
    358
    106
    KC, MO
    Shoot you're not far from Tampa. Look for member tampaprius IIRC. He might be able to lend so nearby assistance. He's a frequent poster.
  12. Eby6114
    24
    Wildwood F L
    Thanks for all your replys, so here we go. Received scan tool today and pulled P0AA4 which is negative contactor stuck closed, also before scan tool arrived did this test. Tested before the two relays pos/neg of hybrid battery 220v never could get voltage thru the two relays, ohmed them NO CONTINUITY , are they being supplied with 12v yes, but once I plug them in I cannot measure voltage, scratching head. I seriously doubt they both crapped out at the same time. Yes 12 volts are going to the relays, but not opening them....
    So in a nutshell no power thru relays, doubt both went at the same time, 220v before relays... what say you?
    Is it possible they both shorted closed no current or nor enough amps going thru but again when I plug in the power of this relay it can no longer be measured and still no continuity
  13. Eby6114
    24
    Wildwood F L
    Is it possible they both shorted closed no current or nor enough amps going thru to open them, but again when I plug in the power of this relay it can no longer be measured and still no continuity across relay, I'm at a loss
  14. bisco
    52,781
    you never tried to jump the 12v, did you?
  15. Patrick Wong
    18,210
    6,517
    I say that either you have a fault with your testing process or else both relays failed. Remove the relay and apply 12VDC across the relay coil. Then measure resistance across the switched contacts. If resistance is more than 0.5 ohm (after accounting for resistance in the test leads) replace the relay.
  16. Eby6114
    24
    Wildwood F L
    Yes have tried jump a starting, I've disco the neg, reset codes, and today removed and gave a solid 12 volt supply to the two main hybrid relays. CLICK on both relays... man scratches head, perfect continuity,but... doesn't respond to the 12 volt feed from the small first relay.. The small relay is connected to the hv, ground, and the 22 ohm resister, power 12 volt comes from the clip coming the direction of the front of the car. Soooo not sure what the hv line and 22 ohm resister accomplish maybe that relay is bad? I saw a post with someone else same problem, is the ecu hybrid location responsible for powering that relay or the ecu under the dash.
    Thinking ecu hybrid or ecu or that smaller relay. Thanks for hanging with me.
  17. bisco
    52,781
    is it possible that you cross polarized the positive and negative when connecting the jumpers?
  18. Patrick Wong
    18,210
    6,517
    It sounds like you don't have the electrical wiring diagram and if so, now is the time for you to get it from techinfo.toyota.com
    The hybrid vehicle ECU controls the three system main relays. The purpose of the relay with the resistor is to allow the inverter electrolytic capacitors to charge up without excessive current surge. After a brief moment, the other relay in the positive circuit shorts out the resistor.
    Have you tested that third relay using a 12V source? Have you examined the resistor to see whether it has any problems?
  19. Eby6114
    24
    Wildwood F L
    Thanks, looks like the resister feed of HV of the smaller relay had an almost broken wire. I made a temp jumper and my car finally started. Will try to clear the codes tomorrow and see in the triangle of death goes away.
  20. Eby6114
    24
    Wildwood F L
    Here is a brilliant feed for future reference for any other new people like myself. It s u own the whole system out of the car. Brilliant work and is a school demo for students.
    . Put everything back together, after the 2nd start no more codes thrown, thanks much to all by the way looks like someone was in here before me. One of the brackets were bent. Looks like they were trying to get to the blower? I didn't have to clear the codes which was great. Thanks again and look at the you tube video I rate it number 1.
