2005 Prius not charging 12v while driving. 195k miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by coastiegunner, Sep 8, 2015.
  1. usnavystgc
    3,159
    990
    Tucson, AZ
    Chap is absolutely correct. Your 12V battery and the respective charging system are fine. Your problem is elsewhere and you need to address that.
  2. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    There have been a couple of reports (rare it's true) of the main 12 volt battery cable corroding through inside the insulation. In both cases this was near the front of the car as the cable goes up to the fuse box. The cable in both instances was made of aluminium and a small perforation in the insulation allowed salt water in to the aluminium, and corroded the cable till there was little or no conductivity.
    I appreciate this is a long shot but it is worth checking out. First by checking one end of the cable to see if it is aluminium then take it from there.
    John
  3. ChapmanF
    18,947
    I never really doubted that, with enough ingenuity, we could stretch the thread out by even more posts about batteries, even if they have to be about "rare" and "long shot" hidden cable corrosion, before arriving at the really rare, super-long-shot, totally black-swan notions, like that the brake lights could actually be about the brakes.
    -Chap
  4. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Yeah might be time to take her to the dealer as we might've just exhausted all common and un-common answers.
  5. ChapmanF
    18,947
    Or even ... just ... read ... the brake codes ... using a Mini VCI or an inch of jumper wire for the blink codes, i.e. a method known to work and pull Prius brake codes, since only an Ultragauge was mentioned earlier ... seeing that the brake warning lights have been on for twenty-four posts already and the common answer of reading the codes to see what they're on about won't have been exhausted until somebody, someday, tries it ....
    -Chap
    usnavystgc likes this.
  6. coastiegunner
    coastiegunner New Member
    louisville KY
    Chap, You may be correct. But if you are correct then the way the system is acting is wrong. why would the lights stay extinguished for a week and then only turn on when just before I can no longer bring the car to ready the next start? My brakes work flawlessly I do my own mechanical work (easy stuff) it does have 90% front pads and same on the drums in the rear, most likely more on both. when I hit puddles the stability control acts as expected ect. If the code for the brakes was for a sensor the light would stay illuminated.. also pending codes as well as active ones would be thrown.. I have had no Issue with my code reader so far and have not had it miss one.. If you have any experience with this gen prius you would know they toss all kinds of lights for bad batteries. (I read everything before I post) I am a fact guy myself and yes what your saying makes sense to the extent that, that is where I should start, but when I take it in and they say there is no code or issue with your brakes that will be 150 dollars for labor please.... oh and by the way we were unable to start your car so please push it off of our lot thank you... Yeah I cant afford that. So Im trying to let you know where I am in the situation. I appreciate your point of view but at this point with no other issues and no codes or pending codes till my battery is unable to bring the car to ready, I am unwilling to spend good money for either no answer or I found this one frayed wire so please buy a battery and wire fixed $550. and the car runs for a week then dead.... I am frustrated with the situation not you chap so please don't take offense to anything none is intended.
    Then why is my new battery as of feburary and tested 2 weeks ago (tested good) leaving me stranded approximately every 8 days? And the last good start ends with the lights.. not warning lights all week just when I suppose the voltage is finally low enough to effect the computers. If this is a coincidence its the biggest ever.
    #26 coastiegunner, Sep 10, 2015
  7. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Not to take this thread, as interesting and riveting as it may be, in another direction, but I have to ask. Why do you have your complete home address listed in your profile? In the world we live in, I find this rather disturbing... If that is not your address, I find it even MORE disturbing. I can't seem to get past this! It is really bothering me! I can even click on it and see what may or may not be your home... I can't even remember what this post was about because I am so fixated on the fact that anyone would do this...
    #27 Eclipse1701d, Sep 10, 2015
  8. usnavystgc
    3,159
    990
    Tucson, AZ
    Idk why that is but every reading you give us says good battery. How about the next time you get those lights and it leaves you stranded, measure the battery voltage and post it here.
  9. coastiegunner
    louisville KY
    and the fact that you put a pic of it on here makes you the one I should be afraid of....
    #29 coastiegunner, Sep 10, 2015
  10. JC91006
    16,933
    8,643
    My guess is OP does not have an adequate device to read Prius codes. There is no way no codes are logged from a NO START event.......along with an eventual red triangle coming on.
    Fiddling with the battery when it's not a battery problem will often erase all codes stored in the car that would point you to the actual problem.
  11. ChapmanF
    18,947
    I agree with usnavystgc, that would be a critical piece of information that's been missing from this entire thread. Coastiegunner, I see that you have mentioned (in post 1, post 26, and post 27) that your car at times will not go READY. In the same places, you mention that the times it won't go READY are immediately after it has posted several, potentially important, dash warning lights. Nobody is suggesting that's "a coincidence"; in fact, if you look in the manual you can find lists of which trouble codes are specified to prevent the car going READY. In all of your posts, you sort of turn it around as "but, why does it report these problems only just before it refuses to READY?" instead of the (rather less mystifying) "why does it only refuse to READY just after reporting these problems?" but maybe it's good to be able to say it both ways.
    Also, in each place you say that, you clearly believe it's not going READY because the battery is too low, but you have not yet, anywhere in a 30-post thread, included even one observation that could help any of the rest of us follow why you think that. I'm not saying necessarily you haven't made such observations, only that if you have, you've never clued us in on them. Are you observing that every time the car won't READY, also the dome light is super dim, the doors only half unlock by remote, the brake accumulator sounds like a dying goose, and the car won't go READY? That would be valuable information to have. So far, all you're saying is "goes great, goes great, then there are these warnings, then won't go READY" and that, by itself, would better support a different interpretation than the one you're giving it. Especially when, so far, you have reported a lot of battery measurements, and you haven't reported any that would suggest a battery problem.
    The best way to fill in that gap would be usnavystgc's way: seeing that you do have access to a multimeter, you could easily just report the battery voltage the next time the car has refused to READY, and that's more concrete and quantifiable than any dying-goose business. That's an easy test you can do without going anywhere, spending any money, or needing anything you don't have.
    The thing about scan tools (I can't speak directly to Ultragauge, I don't have one) is there are a bunch of different computers in a Prius and scan tools won't all talk to all of them, meaning the fact that your tool has shown you codes from one or some of the computers in the past doesn't always mean you can say there are "no codes" on another occasion, if the ones you need to read are in one of the other computers. Anyway, there's also an easy test about that: make a deliberate problem in your brake system (pull a HYDRO MTR relay, say), wait for the dash light, then see whether your Ultragauge reports the correct code for that problem. Again, something you can do without going anywhere, spending money, needing anything new.
    For that matter, just jotting down the blink codes the next time you've got those warnings on is another thing you can easily do, in a couple minutes, wherever you are when it happens, with no money, no hassle, and an inch or so of wire or a paper clip.
    -Chap
  12. Eclipse1701d
    645
    224
    Three Touring
    Now that you have removed your complete address from your public profile, I have deleted the image of your house. I know it was harsh, but I hope you learn from your mistakes...
  13. ChapmanF
    18,947
    Doesn't that entire side-issue seem like something that could have been handled effectively and discreetly by PM?
    -Chap
  14. Eclipse1701d
    645
    224
    Three Touring
    In retrospect, you are probably correct. I was so shocked by it, it didn't even cross my mind. I am so tired of the erosion of our privacy in this country that I am loathe to see it given away, freely... Like our politicians forgetting the fifth and tenth amendments, and the overreach of our judicial and executive branch of government. But, I will leave that conversation for another day.
  15. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    Oh i thought the whole point of social media era was to take 300 selfies of yourself everyday, post them to your real names on various social media outlets so everyone can see.
    Eclipse1701d likes this.
  16. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    OP---what happens after it strands you? do you jump it and its ok? do you have to charge the battery?
  17. epoch_time
    epoch_time Active Member
    236
    110
    las vegas
    Abs lights then red triangle turning on sounds more like inverter overheating do to failed electric cooling pump or hv battery overheating..
    from cloged cooling fan.
    Coastie all your 12 battery readings seem good and battery drain when prius is off is exceptional at .0014
    my 12v battery drain with scanguage connected is around .035 amp.
    It's very easy to check if 12v battery is charging.. turn on headlights. Then ready prius. one second after depression of power button you will see headlights become 15% brighter This is 13.8 volts being supplied to 12.6 volt battery (charging).
    your prius could not run a week on 12v battery that has no charging (only 2.5 hours without lights).. Check inverter coolant reservoir for turbulance indicating coolant flow.
    Inverter coolant pump can also be heard at driverside front fender (with hood open) . also hose from coolant reservoir can be felt for vibration from coolant pump motor/coolant run/flow.
    When inverter over heats or when traction battery over heats. regenerative braking is disabled lighting abs warning lights..
    Your prius only needs to cool down to restart. no jump start nessary.
    Am I right?
  18. spacecar1
    spacecar1 Junior Member
    Denver, CO
    I know this thread is super old but did you ever figure out what was wrong with it?
  19. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I went back a few posts and, as usual, the discussion ran off the rails and went elsewhere.
    The most likely cause when it APPEARS that the 12 V battery is not charging is: The battery itself is worn out and either won't take a charge or won't hold it long.
    It is easy to check the charging voltage with a voltmeter.
  20. spacecar1
    Denver, CO
    Thanks! We replaced the 12v today at the Toyota dealer. Hopefully, that fixes the problem. When we realized that we have had the same 12v for the entire 13 years we've owned the car, we figured it might be that!
