2005 Prius Radiator Fan does not go into high speed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by we6a123, Apr 4, 2015.
  1. we6a123
    we6a123 Junior Member
    Los Angeles
    Does anyone know how the radiator fan goes into high speed? My 2006 Prius A/C works great
    as long as I am moving. But when stopped in traffic or at a light, the radiator fan does
    not go into high speed. So the A/C shuts off until I can get cool air back through the
    condenser.
    I replaced the two fan relays, and when I do the fans run into high speed for a moment, then back to slow speed. Is there a temperature sending unit in the Prius I can replace?
    Any help will be greatly appreciated.
  2. Patrick Wong
    18,210
    6,517
    1. Was the car in a front-end collision prior to your noticing this issue?
    2. If so, check the direction of the air flow when the fans are blowing. Is air blowing towards the engine (which is correct) or towards the front grille (which is incorrect)?
    3. Both fans should turn on when the air conditioner compressor is running. If the compressor is not running, then one fan should turn on once the engine coolant reaches a sufficiently high temperature. That is based upon readings from the engine coolant sensor located in the cylinder head, which provides engine coolant temp info to the engine ECU.
    4. Consult techinfo.toyota.com to obtain the electrical wiring diagram so you can see how the engine ECU and air conditioner amplifier control the two fan motor speeds.
  3. we6a123
    Los Angeles
    Patrick,
    1) Car was never in a front end collision
    2) Direction of Fans in correct direction from front to back.
    3) Both Fans run, but never goes into high speed.
    We replaced:
    a) All the associated fuses.
    b) Replaced A/C Amplifier computer (found in central console at carpet level).
    c) Checked Freon is at correct levels.
    d) Shorted Temp sensor (on Radiator), but fans do not go into high speed.
    Once we resume driving from stop light or traffic stop, A/C works great. Dealer wants to replace entire A/C System (at a cost of $2300) which is not an option for us.
    Any other help would be so gratefully appreciated. we6a at yahoo
    52,790
    how are you determining fan speed?
  5. Patrick Wong
    18,210
    6,517
    If you consult the electrical wiring diagram, you will see that there are three fan control relays, named Fan #1, Fan #2, and Fan #3.
    1. In order for the two fans to run at a slow speed (where the two fans are connected in series from 12VDC to ground), Fan #3 is activated while Relays #1 and #2 remain open. Since the two fans will operate at slow speed, it appears that Fan #3 is good.
    2. Shorting the radiator temp sensor will activate Fan #3, so both fans should operate at slow speed.
    3. In order to get Fan #1 and Fan #2 to activate (where each fan will be connected from 12VDC to ground, hence will operate at high speed), one of three things has to happen:
    a) the pressure switch on the air conditioner refrigerant line has to turn on
    b) the air conditioner amplifier has to activate the two fans
    c) the engine control module has to decide the engine coolant is hot enough to warrant the fans running at high speed
    4. Check the 30A RDI fuse by removing the fuse and using an ohmmeter to verify continuity.
    5. If that fuse is good, remove Fan #1 and Fan #2 relays. Make the Prius READY and turn the air conditioner on. The two fans should not run since the two relays are removed. Short the terminals 3 to 5 which are the switched terminals on Fan #1 relay to see if one fan will run at full speed. Then, remove the short and short the terminals 3 to 5 on Fan #2 relay to see if the other fan will run at full speed. Remove the short, then short terminals 3 to 4 on Fan #2 to confirm that both fans run at slow speed.
    With either relay, make sure you do not short terminals 1 and 2 together
    , which are the relay coil terminals. Use an ohmmeter on the relay to identify the coil terminals vs. the switched terminals. The coil terminals will measure ~100 ohms or thereabouts.
    6. If you can get both fans to run at full speed by shorting the relay terminals, then there may be something wrong with the junction connection between the two relays and the wires that provide connections for the three items 3a, 3b, and 3c.
    7. If you cannot get the fans to run at full speed then there is some obscure problem with the relay wiring. Hopefully you won't need to get this far.
    fragglestickcar likes this.
  6. we6a123
    Los Angeles
    Thank you Patrick for the reply. I'll go and try your suggestions. BTW: Where is the A/C sensor switch located that tells the fans to go fast? I know where the Radiator sensor is, but not the A/C Sensor.
    Thanks again.
  7. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    P1 pressure swish is at the AC sight glass.
    Turn AC to max cold with high fan speed and then unplug it.
    If the fan speed drops fans were already at full speed (and that switch is OK). Don’t leave it like this for long.
    If the fan speed didn’t change. Then either you have bad swish, or pressure just wasn’t high enough to need full fan speed, or you have some other electrical problem. Then you can bridge the two wires in this connector. If fan speed now increases you have bad swish, or pressure just wasn’t high enough to need full fan speed. If it still doesn’t increase you have some other electrical fault.
    #7 valde3, Jun 8, 2015
    we6a123 likes this.
  8. we6a123
    Los Angeles
    Thanks so much for your reply. When I pull out the wires from the switch on the AC Sight glass, the two fans and A/C Compressor stop altogether. There are 4 wires on the plug. One is Red, the other is Green, and there are two white/black wires. Which wires do I need to bridge together?
    Again, the two fans NEVER go into high speed. That seems to be the crux of the problem.
    Thanks again.
  9. valde3
    2,002
    750
    Finland
    I didn’t realize pressure switch has double function. Unplugging it will turn the AC off because of the low pressure switch that is connected to pins 1 and 4.
    Connect the pins 2 and 3 colors light green and white with black stripe and you should get the fans to full speed. It shouldn’t really matter which white with black stripe you connect the light green wire. Disconnect the connector and bridge them from the front side. If you then get the full speed, that you haven’t gotten when you should, you just need new pressure switch.
    If you didn’t get fans running by bridging, disconnect the 12V battery for 10min or so to clear the codes you caused. And then we can get back to trying to find problem with wiring, relay, or fuse. Or if you decide to get it to somewhere they don’t get confused by those codes.
    Patrick Wong likes this.
  10. Patrick Wong
    18,210
    6,517
    I actually think that switch connected to pins 1 and 4 is a low pressure switch as well as a high pressure switch. So if the refrigerant is either under- or over-charged, the circuit will open.
    I agree that it would be a good test to try bridging the wiring harness connector to see what happens with the radiator fan speed. If that pressure switch turns out to be the problem, the OP needs to have the switch replaced by his local Toyota dealer or an independent competent to work on the Toyota hybrid air conditioning system - since the refrigerant will need to be removed from the system prior to the switch being unscrewed.
  11. we6a123
    Los Angeles
    Just tested the Blue to White/Black wire and the fans went into high speed! What a joy to finally figure out what is wrong with the A/C when stopped in traffic or a stop light. Now need to find the right people to evacuate the Freon Gas and replace the faulty switch. Thanks so very much for helping me with this unique problem. Kudos to you both!
  12. valde3
    2,002
    750
    Finland
    You will need place that has equipment for high voltage hybrid AC. Independent hybrid specialist or Toyota dealer will probably be the best option.
  13. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    Shouldn't the switch be tested based on the pressure in the system? Based on the above comments, it seems like the OP might be about to replace a switch he doesn't need to. What if the high side pressure isn't high enough for the switch to turn the fans on to high?
    Avi
  14. Avi's Advanced Automotive
    776
    363
    Now, I have some questions:
    1. Has anyone ever messed with the refrigerant?
    2. How was the fact that the refrigerant level is correct determined?
    3. What was the high side pressure at when the switch was tested?
    Thanks,
    Avi
  15. Patrick Wong
    18,210
    6,517
    The OP says the AC "works great" when the car is moving, which implies that the refrigerant level is reasonable. However, as you suggested, it would not hurt to have the low and high side pressures measured before the switch is actually replaced, to verify that the switch is the problem vs. insufficient refrigerant charge.
  16. we6a123
    Los Angeles
    Well, we followed the suggestions, bought a new switch, paid to have the freon evacuated, replaced the switch, and replaced the freon. No change. The fans still do not come on at high speed on a hot day. The freon levels are good, but the A/C mechanic noticed the low pressure on the compressor was too high. Again, once we are moving the A/C works fine. We will bring the car in again for more tests and inform him that the low pressure side should be within 0.15 to 0.25 MPa.
    When we had it analyzed at the Toyota dealer, the guy mentioned the receiver dryer had a "special valve" that was getting stuck. We do not know if that might be the cause of the low pressure side being too high. But they wanted to replace both the compressor, drier, and condenser for $2400.
  17. Avi's Advanced Automotive
    776
    363
    Is it really that hard to find a shop that knows how to fix the A/C on a Prius in Los Angeles?
  18. we6a123
    Los Angeles
    Well we finally found the solution to our ongoing problem. Let me say first that 2 different Toyota Dealers recommended to replace the condenser and compressor at a cost of over $2100. I did bring it to an independent A/C and Radiator shop Reseda A/C and Radiator. They discovered a broken Fuse in the in-line dual fuse block. It was a 30 amp RDI fuse that gives power to the Radiator and Comdenser Fans. We repaired the broken fuse, and all is now resolved. Cost was $65. The RDI fuse was repaired, it now powered the relays on, which in turn, turned on the Radiator/Condenser Fans.
    A good question to ask; what would cause the RDI Fuse to blow???
  19. valde3
    2,002
    750
    Finland
    Fault in Radiator fan (not condenser fan) or short in wiring. But if the fuse was blown jumping the pressure switch wires should only make condenser fan run at full speed, radiator fan wouldn’t run at all.
  20. Avi's Advanced Automotive
    776
    363
    It is hard to tell the difference. He might have heard only the condenser fan run at high speed and thought it was both fans. The only time I've had to replace those was when a fan motor was defective. I've seen them still work but draw too much current. Usually the car was in an accident and had the fan hit the radiator.
    Fred14 likes this.
