2005 Prius, Red Triangle, powers on, no start. New 12v battery.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by alleneatsapples, Oct 22, 2021.
  1. alleneatsapples
    alleneatsapples Junior Member
    Kauai
    2005 Prius with about 160k miles. Red Triangle and the P3000 code came up. Powers on with all the dash lights and monitor, no start though. Could it be the starter? Anyways, I bought a new 12v and that did nothing. Any suggestions would be awesome.
    -Allen
  2. JC91006
    16,936
    8,647
    A little history on the car? Did all this happen out of the blue? Has car been sitting? Is there gas in the car?
    SFO, Raytheeagle and alleneatsapples like this.
  3. alleneatsapples
    Kauai
    Hey! Thanks for replying. The previous owner said it did sit for a couple months and I am not sure if there is gas in it since the gas gauge is flashing with full bars.
    The previous owner said it died on the road suddenly, then started back up, then eventually died again.
    I will fill it with some gas and see where that gets me.
    Any other inputs would be great. If someone can help me diagnose the problem and chat over a phone call, I can pay you. 715-201-9153
  4. JC91006
    16,936
    8,647
    Try putting 3 gallons of gas in it and try to start it again. Make sure the 12v battery is good too.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    The fuel gauge flashing with FULL bars is unusual. On a loss/restoration of 12v power, it will flash one dot until it recalibrates itself.
    Full Bars flashing could be trying to give you a flash code or just be indicative of a communication issue.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    What are you using to check for codes? P3000 is a code that says "hey, the HV battery ecu says it sees a problem- go check there for codes". So whatever you use to scan the car has to be able to check all modules on a Prius for codes. Many here will get a mini VCI cable with a bootleg copy of Techstream (Toyota's diagnostic software) and install it on an old windows laptop.
