2005 Prius: red triangle, VSC, (!) lights, C2318, P3000, P0A81 after Prolong charge - help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dex3703, May 19, 2018.
  1. dex3703
    dex3703 Member
    65
    31
    Seattle
    Hello,
    I have a 2005 Prius with 130K miles. I've been using the Prolong charger without any issues but am suspicious after my most recent discharge/charge when the above problems surfaced.
    The red triangle, VSC and (!) lights came on about a week after a Prolong charge/discharge/charge conditioning. I looked around this board and saw the post about it being the inverter coolant pump, but when I pulled the codes that doesn't seem to be it. Also, the pump seems to be working fine: I can see the coolant rippling and feel/hear the pump running.
    My girlfriend's son works at a Hyundai dealership and pulled these codes for me (descriptions are from the Snap-On reader; I didn't look them up):
    C2318 - Transmission low voltage
    P3000 - got two of these, one on the HV ECU and another one I didn't catch the detail of - "low voltage"
    P0A81 - HV battery coolant fan low voltage
    Measuring the little 12v battery from the relay box gives me 12.08 volts with the car off. I didn't check with the car on. The battery is an Optima yellow top I put in 12/5/14 with 104,300 miles.
    The car drives fine. I'm getting 53mpg. It's behaving normally except these lights are on.
    Looking for suggestions of what this could be. I'm guessing it's probably the HV battery has one or more bad modules :( but am open to suggestions! I wouldn't think the 12v battery would be bad after 3 years.
    Also--am I damaging the car driving it?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    With the battery fan low voltage code, I have some additional questions ;):
    • Is this the first time you have hooked the harness up?
    • Did you check the electrical connection for the fan to ensure it is tight?
    • Did you hear the fan running during the reconditioning process?
    The 12 volt battery also appears low, so I’d charge that up to ensure you are not getting codes due to a low 12 volt battery;).
    Keep us posted (y).
    edthefox5 and SFO like this.
  3. dex3703
    dex3703 Member
    65
    31
    Seattle
    Hi Ray,
    I've had the charger installed for over a year. I've done the charge/discharge/charge several times, no problems until now.
    Raytheeagle likes this.
  4. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Have you looked at the hv fan to see if the connection is good or if it is running? If it is not running, you’ll get a notification in the dash and a code:).
    There have been some cases where the fan has failed. With Techstream, you can vary the 6 speeds of the fan;).
    I’d look there and see what you find. While investigating the fan, might also want to check its cleanliness. You might be surprised with what you find:eek:.
    Keep us posted (y).
  5. dex3703
    dex3703 Member
    65
    31
    Seattle
    Thanks Ray! The Prolong charger makes the fan run, so I'll see if that makes it go. The little supplemental fan controller box that comes with the Prolong can kinda rev its own fan up/down sometimes, but Prolong said that was normal. (?) I don't have my own reader. Will let you know what I find.
    Oh, and when I installed the Prolong harness, the HV battery fan was surprisingly clean.
    edthefox5, SFO and Raytheeagle like this.
  6. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Yeah the Prolong fan is separate from the cars, and while I’ve not heard it vary much, that doesn’t mean it doesn’t. I have the Intelligent Discharger and I set the equipment up and then don’t have to worry:).
    The fan in the Prius during Prolong operation runs at setting 6 or full blast;).
    If you plug in the Prolong charger and you hear the Prius fan, that’s good:).
    Keep us posted (y).
  7. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    For under $75 you can purchase the needed diagnostic hardware and software that will privpro helpful data so you can reduce the amount if guesswork.
    - Android phone/tablet (under $45)
    - Torque Pro app (under $10)
    - Elm 327 Bluetooth OBDII adaptor (under $20)
    This will provide you voltage data for HV Battery, voltage data for the modules, 12v battery data, HV battery state of charge, etc all in one screen.
    Until then we will just be guessing at the problem.
  8. dex3703
    dex3703 Member
    65
    31
    Seattle
    What's the best OBDII connector/cable to use? I find a lot of pages in iffy English and others about how much these readers suck.
  9. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    Best? Well it won't be the under $20 one.
    Best one is more like $50: OBDLINK LX.
    But many of the cheap, under $20 are adequate.
    Heck even with some of the $5 ones you could just buy a couple and toss the unusable ones in the trash.
    The names and links change/vary, but they look something like the attached pic.
  10. dex3703
    dex3703 Member
    65
    31
    Seattle
    I looked up that device on Amazon where this is clearly stated:
    Note: This product is not compatible with hybrid or electric vehicles
    Can somebody recommend a scan device that will work with a Prius?
  11. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    I use a kiwi2 for the normal codes that I carry in our Prius (have not had any hybrid codes displayed so not sure if it works for that, but doubt it), then have a j2534 Mini vci cable I got off of amazon that allows for the use of Techstream :).
    In order to use Techstream, you’ll need an old laptop, but those are prevalent ;).
    But this setup works well(y).
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Thanks for the post your the first one that’s mentioned the fan speed going up and down during charge.
    Mine does the same. I have the original style charger only with light bulb discharger.
    I was thinking the fan controller was bad and was getting hesitant to use the prolong.
  13. dex3703
    dex3703 Member
    65
    31
    Seattle
    Thanks Ed. Please note that the PROLONG fan controller box is the one with the fan that revs up and down. The car's built-in battery fan does NOT rev (at least as far as I can tell).
    I have the same setup as you (light bulb discharger and the round charger). I was told by Prolong their fan revving doesn't harm anything so I have kept using it. Is this true?
  14. edthefox5
    10,096
    4,836
    Clearwater, Florida
    Ok mine does that too lol. Was hoping that you were talking about the cars battery fan. Both my fans go up and down. i notice if I smack the charger base unit the charger fan stops doing it for a while but the car battery fan does not stop doing it. I have already taken the charger case off and its a home made looking thing.
  15. edthefox5
    10,096
    4,836
    Clearwater, Florida
    In order to hear the CARS battery fan over the charger fan ruckus you have to listen to the fan at where it dumps out above the 12 volt battery. The prolong battery charger base unit fan issue made me worried the car's battery fan may be doing it too and it is. It consistently goes up and down. It revs up then revs down. My car fan is very clean and I oiled it too. I have good airflow out also.
    I bet alot of units are doing it just nobody ever noticed except suspicious me.
    #15 edthefox5, May 20, 2018
  16. edthefox5
    10,096
    4,836
    Clearwater, Florida
    If your getting 53 mpgs your battery is probably ok. I misread the discharging instructions and did a very abbreviated discharge the first and only time and it came out really good. Its been more than a year and my battery acts like its brand new. Consistent 50 mpgs. I know I'm just staving off the inevitable but an abbreviated first charge may actually be the thing to do.
    When mine poops out again I will do the full 3 day discharge/charge/discharge/charge/discharge...lol...
    dex3703 and Raytheeagle like this.
  17. edthefox5
    10,096
    4,836
    Clearwater, Florida
    Your battery modules themselves may be ok but you probably have some corroded terminals issue based on the age of it.
    If I received those codes about the battery I would pull it out and take the cover off it and take a peek at the battery. Take alot of pictures of it. Look for green corrosion on any of the terminals. They must be cleaned. Duke your girl friends son to help you pull it out and fix it. Once he learns he can make some good money doing it on the million other dying Prius's out there.
    Hundreds and hundreds of pictures and posts about this.
    And you need a new 12 volt battery. A healthy Prius battery should be at 12.6 volts. My bought new Yellowtop lasted exactly 2 years 350 days. I got Autozone to prorate me another. Free!
  18. dex3703
    dex3703 Member
    65
    31
    Seattle
    @edthefox5 :
    Thanks for the info!
    • I've also done just one discharge/recharge the past two times. That's what gets me above 50mpg. I use the big bulbs to the first setpoint, then change to smaller bulbs and keep going down. The lowest I've gotten was 40 volts, so that's a lot higher than 17. I did this just before this problem started.
    • I can hear the inverter pump and see the fluid moving, so guess that's not it.
    • 12v battery seems to be biggest suspect:
    1. I checked it at front of the car and got 12.08 volts with the car off.
    2. Checked at the battery last night after driving 20 miles and got ~12v again.
    3. Put it on a 2A charge overnight and drove 15 miles. Lights stayed off until the very end of my trip, when the (!) and VSC lights came on again.
    4. 3 1/2 years for an Optima yellow top? That sounds really low miles! Is that really what I should expect?
  19. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    You can remove the 12v and have it load tested at an auto parts store that offers such service. If it passes then......
    You can stress test the HV battery in your driveway by force charging (car in D, parking brake on, brake pedal pressed, and floor gas pedal till battery SOC goes full blue bars), then force discharge by putting car in N, high beams on, and full a/c (LO temp, high fan) till SOC drops to purple bars. Time each process. Rinse, lather, repeat, 3-4 times and see if codes come back and/or get big variations in time intervals.
  20. dex3703
    dex3703 Member
    65
    31
    Seattle
