2005 Prius - Right taillight LED going dimmer and dimmer...
Discussion in 'Gen 2 Prius Technical Discussion' started by aliensporebomb, Jun 6, 2016.
  1. aliensporebomb
    aliensporebomb Junior Member
    Minneapolis, MN, USA
    So, if you've ever replaced bulbs in your Prius you'll notice that the rear taillight assembly has a light source on the very top that you just can't replace.
    It appears to have a similar release collar than the lower bulbs but this fails to release.
    So, I've been told by my Toyota dealer that they will have to replace the ENTIRE right rear tail-light housing since those bulbs are LEDs and as such are non replaceable. So to replace the right rear tail-light assembly will be to the tune of about $250.
    What if the left side does the same thing not long after?
    Has anyone experienced this where the very top portion of the taillights are dimming to invisibility?
    Anyone have a better method for replacing this?
    Anyone wonder why Toyota didn't make those light sources replaceable too?
    Let me know what you have encountered. The parts are in Chicago (I'm in Minneapolis area).
    -T
  2. JC91006
    16,936
    8,647
    EBay is your friend for parts
  3. aliensporebomb
    Unfortunately I have no automotive knowledge to safely install said assembly. I found one video from a couple russian guys who had to remove the bumper, a lot of the back end hatch area - that seems crazy! Seems like Toyota made the assumption people would be selling these cars prior to 10 years of ownership and just assumed the LEDs would last forever.
  4. JC91006
    16,936
    8,647
    The bumper does not need to come off. It's simply removing some nuts off bolts. Possibly 3 of them
  5. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    Don't blame Toyota! Actually car manufacturers aren't allowed to install changeable LED lights (except interior lights). So they have to use complete assemblies - at least in several countries. But they won't use other assemblies in a few countries, even if it would be allowed, if they don't have to.
    I think it's because many people wouldn't choose the right led for replacement. A bulb has information (voltage, electric power input) at the socket, no problem. But for LEDs you need a proper data sheet with voltage, light power output, beam angular, wave length or color temperature (maybe I'm not using the correct English terms) to be sure having the right led.
  6. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    Recommend you do it yourself, buying an assembly off ebay or elsewhere for low cost. Very easy to do with a basic set of wrenches. See this video.
    It's good to learn to do simple car repairs like this one, as doing this kind of work will save you thousands over your life. Also very gratifying to fix things yourself :) Otherwise the dealer's price is reasonable IMO, but I'd never pay them $250 to do something I could do myself in an hour for less than $75.
    As far as the other side goes, the failure rate on electronics is generally close to flat after the initial break in period. This means that a 5 year old LED is only a little less likely to fail than a 10 year old one over the same time period. If you've replaced the first side yourself, then if the second one fails, you'll be able to do the job in half the time.
    The reason that the LEDs are not replaceable is that they are never expected to fail. LED bulb life is typically around ~50,000 hours. If they were on continuously for this time (which your brake lights won't be), and you averaged 30mph in the car (which is about average) that works out to an expected life of 1.5 million miles. However, sometimes you get unlucky, or water gets into the assembly and corrodes things, so very rarely they need to be replaced. You probably just got unlucky.
    #6 Kevin_Denver, Jun 10, 2016
  7. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    While LEDs can dim over time, it's somewhat unlikely that the entire array of them would fail at the same time. I'd check for a faulty connection (e.g., loose, corrosion, etc) between the car wiring and the taillight assembly before replacing anything.
  8. Dustin92
    Dustin92 Junior Member
    37
    Jackson, Michigan USA
    My 2004 is doing exactly the same thing, the right led's are dimming, one or two are dead and another flickers. Not going to replace it until it totally dies, and I'm at risk of getting a ticket.
