2005 Prius screen isn't accurate!!
Discussion in 'Gen 2 Prius Fuel Economy' started by Eddie Brown, Feb 28, 2013.
  1. Eddie Brown
    Eddie Brown Junior Member
    26
    Chicago
    Hello,
    I just bought my 2005 Prius with 70K and the display is not giving me an accurate reading.
    I'm down to two fuel bars and I've driven 314 miles. The screen is telling me that I'm averaging 45.1 mpg. This information is based on a full tank of gas.
    85% of my driving is Highway 60-70mph and on CC
    What could be the problem?
    Thanks,
  2. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    It's not based on a full tank of gas, it's based on how much fuel goes thru the engine and the miles driven. You have a rubber bladder in the tank, in cold weather you can not fill up as much as in warm weather so judging by how much is left in the tank is innaccurate.
  3. Eddie Brown
    26
    Chicago
    So averaging 28 mpg in the winter time is accurate for a 2005
    I just don't understand why the screen is telling me I'm averaging 45 mpg but the gas gauge is saying something different
  4. Munpot42
    1,391
    544
    Because of the rubber bladder in the tank, filling it up takes different amounts due to the flexability of the bladder. Ergo on cold days the tank will hold less fuel than on warm days.
    Question: Did you calculate your 28mpg by filling up the tank, driving 314 miles and filling up the tank again, then dividing the number of miles driven by the amount of gas it took to fill up again? If you did you had to put in over 10 gallons, with the fuel guage on two pips, that seem either unlikely or your fuel guage is not working.
  5. Eddie Brown
    26
    Chicago
    I haven't filled up yet. I will later tonight.
    I calculated the 28 mpg by the miles I have driven so far and divided it by the tank size.
  6. fuzzy1
    10,687
    This doesn't work at all. Just like on most other cars, the fuel gauge doesn't represent the whole tank, and the bars are not linear. And specific to the Gen2 Prius, the rubber bladder throws a major wrench of inconsistency into the calculations.
    Your MPG must be determined from fillups. And because of the bladder, you will need to keep a fuel log and average together many consecutive tanks if you want an accurate figure.
  7. Eddie Brown
    26
    Chicago
    So, should I go off of the screens 45 mpg and fill up roughly at 400 miles or should I listen to my gauge and fill up now at 314 miles
  8. Munpot42
    1,391
    544
    Hard to be accurate when the tank size varies, they got rid of the rubber fuel bladder starting with the 2010 model year, so your calculations would be a little more accurate, however miles driven divided by amount of gas used will be more accurate. The display is usually optimistic by between 2 and 4 mpg high, so your 45 mpg reading shoud really be between 41 and 43. Enjoy your new ride, you'll know more about it's fuel mileage after a few tanks.
  9. fuzzy1
    10,687
    For your first tank of a Gen2, fill up now. Don't go below 2 bars until you know how much that takes and whether or not the bladder will cause repeatability problems.
    Some Gen2 users have habitually gone well beyond the single blinking bar without any problems, but some others have run dry with a solid bar or even two solid bars. JimboPalmer, who ran out 7 miles after the last bar started blinking, espouses this rule:
    When alone, fill up at one bar. Known one else needs to know that you ran out.
    With the spouse in the car, fill up at two bars.
    With the mother-in-law in the car, fill up at three bars. She will never let you forget being stranded.
    volloeko, F8L and ewxlt66 like this.
  10. Munpot42
    1,391
    544
    I fill up at 2 pips just to be on the safe side, I think you would still have a gallon in the tank when you get to the start of one flashing pip. From where you are now, you should be able to get to 400 miles, but I would not risk it.
  11. Eddie Brown
    26
    Chicago
    Thank You guys for the information.
    I will post an update after my third fill up
  12. fuzzy1
    10,687
    Don't wait, give us an update after today's fillup. It won't be real accurate, but it ought to be much better than 28 mpg.
  13. uart
    uart Senior Member
    4,220
    1,212
    Australia
    I don't see the problem. In theory (if the gauges are accurate) then you will have used 7 gallons. What makes you think that you haven't used 7 gallons?
    How many gallons did you fill it with?
  14. Eddie Brown
    26
    Chicago
    I bought from the dealer with a full tank
  15. uart
    uart Senior Member
    4,220
    1,212
    Australia
    No worries Eddie, I see what the problem is now. Yes, you're just over-estimating how much fuel was in it when you got it. When you go to fill it up you'll find that it wont take anywhere near 12 gallons, due to the rubber bladder in the tank.
    Also, even in overseas models where we don't have the tank bladder and can easily put the full 12 gallons in, the fuel gauge will still show full after only about 9.5 to 10 gallons. So the bottom line is, unless you filled it yourself you just don't know if it was truly full or not. Due to vagaries of the refill volume it's best to average it over a few tanks if you want to get good MPG data.
  16. fuzzy1
    10,687
    Maybe, maybe not. For MPG calculations, it doesn't really count until you fill the tank yourself.
    The dealer could have filled it a bit short, or sent it out on a number of test drives that burned off the top gallon before you reset the MPG display.
  17. Eddie Brown
    26
    Chicago
    My fault guys I actually had 275 miles not 314.
    I just filled up with 6.504 gallons
  18. Eddie Brown
    26
    Chicago
  19. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    As other's have stated, the bladder will shrink when it is cold, and also stretch when it is warm. Cold temps such as what you are experiencing will also cause the mileage to suffer slightly. Based on what I am seeing so far on your fuelly report, I think you are doing Ok. To get a really good average you will have to fill the Prius several times before you can get a true average of your MPG. Click on my fuelly in my signature and study what you see there. It should give you an idea of how temperature and city vs highway will affect the MPG.
    There are a lot of tips and tricks you can employ to maximize your mileage.
    Take a gander at the link below and try to apply some or all of the items mentioned. It takes a while to learn how to really get good MPG on the Prius. If you apply everything, you will find that you can either meet or beat the EPA standards. Remember that your mileage will vary.
    Beating the EPA - The Why’s and How to Hypermile - CleanMPG Forums
    Good luck to you and enjoy your Prius.
    F8L likes this.
  20. Eddie Brown
    26
    Chicago
    Should I not pay attention to the fuel gauge on this fill up and just fill up at 400 miles since I'm averaging 42 mpg?
