2005 Prius Starting Issues
Discussion in 'Gen 2 Prius Audio and Electronics' started by Jason Heeren, Nov 12, 2020.
  1. Jason Heeren
    Jason Heeren New Member
    Iowa
    Hello-
    My 2005 Prius is acting very strange lately. There are times where I will get into the car, try to start it, and it is completely dead. This happened today then, when I was just sitting there pondering what to do next, it randomly turned on! There have also been times where I have turned the car on to notice the clock, heat/air, fuel mileage, and trip meters have all been reset. I just put a new battery in about a month ago.
    Thanks for the troubleshooting advice.
    52,705
    make sure the battery is good, then begin troubleshooting. how many miles on her?
    kenoarto likes this.
  3. Jason Heeren
    Iowa
    I would think the battery should be good. It's only a month old. She's got 185,000 miles on her.
  4. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    COVID driving can be alarmingly minimal. Once a 12v battery is fully discharged, bad things happen. Have you tested the 12v battery voltage after a full night's rest? FYI: I bought a trickle charger.
  5. Jason Heeren
    Iowa
    No, I haven't, but I drive the car daily. I have a trickle charger. Should I hook that up in the front engine compartment or directly to the 12v battery in the back?
  6. bisco
    52,705
    either place
    if it's not the battery, it could be the connections, especially 12v neg to ground.
    or it might be a bad combo meter
  7. kenoarto
    398
    Chicago, IL
    Check the battery voltage after a full night's rest. How far do you drive every day? Do not charge before you test.
  8. Jason Heeren
    Iowa
    Update: Took it to my local mechanic. He did a diagnostics test and discovered a short. Found out it was a loose wiring loom behind the fuse box. He tightened that up and did another diagnostics test and all came back fine. Hasn't glitched since. Here's hoping it was only a $140 fix!
