2005 prius throwing code p1121 is this the 3 way valve or throttle position sensor?
Discussion in 'Gen 2 Prius Main Forum' started by Prius Rising, Mar 31, 2019.
  1. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Occasionally I have a hard stumble on engine shut down, though rarely. Thinking once a month or so. Will have to keep track now.
    Also been having issues with the pending cat code, it comes and goes and now is being thrown more often again. Thinking I will give a new upstream sensor a shot.
    Where was that accelerator pedal sensor knowledge found?
    Have you replaced either the upstream or downstream sensor, and did you use the Denso sensors?
  2. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    I did replace the downstream sensor I’ll check the brand
    iPhone ?
    PriusPaddler and SFO like this.
