2005 Prius w bad hybrid cell
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Aryiana, Apr 13, 2009.
  1. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    Also a bit of my thinking. New battery with installation costs 3 k $. What is the price of new equivalent Prius currently? Most probably above 23k $, so let say around 24k, which brings 3 k $ to around 1/8 or 12.5% of the price of the new car.
    So you can see this battery failure as the 12.5% price increase of the new car. But with this price increase you will also probably gain additional 150 k miles of your car life. So it is not all bad.
    We all know that battery in Prius will die. On some sooner, on some later. 150 k miles is not so bad in my opinion.
    If you buy a modern VW diesel car, you will probably have some major component failure during this time anyway. Usually the turbo charger, but also other stuff usually dies in a typical VW TDI car. Not to mention higher costs of maintenance.
    Also few technical questions of mine:
    How was the car driven? Mixed terrain, hilly roads, flat highways, city driving ...
    So keep us posted and good luck of course. ;)
  2. richard schumacher
    7,683
    1,066
    United States
    Rubbish. Data show no such thing. The OP was merely one of the unlucky few.
  3. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Rubbish what? He is just one of the unlucky ones that fall into the statistic of failure.
  4. richard schumacher
    7,683
    1,066
    United States
    Perhaps I was hasty: you gave the failure rate as 50% after the warranty expires. How do you define failure rate? It's certainly not 50% per ensuing year; 50% per ensuing decade, maybe.
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Duffy's Taxi in Winnipeg does not agree with that. They have a large fleet of Prius as taxi's, with several needing battery replacement. Overall the fuel savings more than pay for a small handful of failures, though it sucks when statistics conspire against you
    Consider that for a taxi fleet, there is no way in hell they'd get +150,000 miles out of a Crown Vic transmission. In hard city use, they will replace quite a few in the fleet.
    Overall, the Prius holds up well, even in Winnipeg with -40 winters, and horrible road conditions. They are usually totalled in crashes involving stolen cars driven by joyriding punks
  6. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi All,
    So, we are talking cost of Ownership. Lets see, $3000/156000miles is $.0192 per mile. Having that battery in there results in getting 50 instead of 25 mpg. So, over 156000 miles that saves 3120 gallons. Using an average of $3.00 per gallon since 2005 we get $9360 saved over 156000 miles, or $.06 per mile saved.
    Putting it altogether, even if Aryiana buys the new battery, and the car gets into an accident the next day, she still has saved (.06 - .0192 - .0192)*156000 or $3837.60. Or more than enough for even a third battery and still come out economically ahead!
    So, I do not see the reason to carp about the lifetime of the Prius battery in this situation. The original battery in there car saved $9360 in gas, but cost $3000 installed new (presumably). Right now, they are $6360 ahead. If they put in the new battery at $3000 they will get back to $6360 total savings in only another 50000 miles at $3.00 per gallon average cost, and 75000 miles at $2.00 per gallon. I am sure there are plenty of people out there willing to buy Aryiana's car sans battery and take that bet.
    Oh, Aryianna, be sure to put $500 away for new brakes. At 156000 miles your about due for your first brake job on that car.
  7. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    Donee, factor in the fact that the car is driven for work/business and a considerable portion of that mileage (should have been) is tax deductible, or that mileage compensation is probably paid by her husband's employer, furthering the savings in your comparison dramatically.
