2005 Prius Warning Light Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ryankmasuda, Jan 30, 2018.
  1. ryankmasuda
    ryankmasuda Junior Member
    Yacolt
    Hello,
    I’m a fairly new owner to my 2005 Prius and I’ve had a “triangle of death” light come on occasionally. First it started once a month, then once a week to once a day. As of today it has popped up four times in my 40 minute commute. I’ve tried reading a code using my Scan Gauge but no codes are being thrown. No other warning lights are popping up either. The head unit also says “Problem” across the screen for a split second then it disappears. Is there a simple and easy fix or is this the “triangle of death”?
    iPhone ?
  2. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    That is the incorrect interpretation. You have code(s), ScanGauge is not reading it/them.
    • How many miles on the ODO?
    • Have you checked the radiator fluid level – the radiator, not the overflow container?
    • Have you checked the oil level?
    • Have you checked the inverter coolant reservoir level and checked that there is fluid movement when the car is in IG-ON or READY?
  3. JC91006
    16,937
    8,647
    I second the suggestion of checking all your fluid levels. I suspect your oil level is low
    dolj likes this.
  4. dolj
    dolj Senior Member
    8,652
    4,403
    I suspect one or more of them are low.
  5. bisco
    52,878
    how many miles on her?
  6. ryankmasuda
    Yacolt
    I have not checked my fluids yet. I just hit 219k
    iPhone ?
  7. bisco
    52,878
    if the fluids are okay, check the trouble codes.
  8. JC91006
    16,937
    8,647
    These cars burn oil when they are old. More so when the owners run them until the warning lights come on. You should check the fluids before driving the car again.
    I see a newer engine in your near future
  9. dolj
    dolj Senior Member
    8,652
    4,403
    How many of those have you put on it?
    Is the service history up to date?
  10. ryankmasuda
    Yacolt
    I checked all my fluids. My oil was low but in between the two markers on the dipstick. The radiator fluid was at the neck, below the cap and my inverted fluid seems to be above the bottom mark but not by much. What type of fluid do I need to top off the inverter coolant?
    iPhone ?
  11. JC91006
    16,937
    8,647
    Interesting, I was pretty certain it'll be low on fluids.
    There are codes stored, you'll need to get them read. you'll need access to a reader that can read prius codes
  12. dolj
    dolj Senior Member
    8,652
    4,403
    Both the inverter coolant reservoir and radiator take Toyota SLLC (Super Long Life Coolant). This is pre-mixed, ready to use
    Now that you've confirmed the radiator is full to the top of the neck, ensure the overflow canister is between the Full and empty marks too.
    Oil is ok if it showed between the bottom mark (low level) and the top mark (full level), my preference is for it to be nearer the F mark than the L mark.
    You didn't say whether there was good fluid movement in the inverter coolant reservoir. If the radiator and inverter coolant haven't been changed in the last 50,000 miles, then they should both be completely changed.
    #12 dolj, Jan 30, 2018
  13. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Regardless of previous posts.....my vote can be placed under the oil pressure column. Easily checked just by topping off the oil level and then doing the daily commute....
  14. ryankmasuda
    Yacolt
    I do notice the souls of fluid movement during the start up.
    I’ll be sure to bring all my fluid up to full and see if that makes a difference.
    Can anyone recommend a code reader that reads Prius codes?
    iPhone ?
  15. ryankmasuda
    Yacolt
    Update, I did not hear the sounds of liquid passing when I started my Prius today nor did I hear it at any point in my commute. Is there a thermostat that needs to be replaced?
    iPhone ?
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Sounds of liquid passing?
    Your car was run so low on oil the oil pump is sucking air that will launch the triangle of death. Zero oil pressure. Unfortunately one of those events sometimes causes the car to really start eating oil as it will cause engine damage. The engine is already eating oil that's why its so low. You have to check the oil very carefully for a while to get a handle on how bad it has become now.
    But, how come with such a very noticeable and scary alarm light you cant even open the hood and check the easiest thing in the world?
    You go through the trouble of taking a picture of the alarm and then posting it and a story and wait for replies. That's alot of effort.
    Better spent opening the hood. See this very often here. Its very perplexing. Many a perfectly fine Prius engine has been blown from lack of opening the hood. For many people its a financial disaster when they blow a motor.
  17. JC91006
    16,937
    8,647
    To get a proper reading on your oil dipstick, it's best to do it before you start the car in the morning. You'll get a real good and clear reading that way
